2017 cruise intermittent cruise control not working
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Treemendos, Apr 4, 2017.
  1. PCTN
    PCTN Junior Member
    Tennessee, USA
    I’m in the states. The first time it happened I was attempting to set it for 55mph. I can’t remember the exact speed I was going the other times, but since I was on the interstate it was probably between 75 and 80. (Lead foot)
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    One other possibility - when I was new to my PRIUS, I'd accidentally knocked the dumb button on the end of the stalk while manipulating the stalk, turning it off.
    The Motoring Press were in raptures when they reported that TOYOTA have finally got rid of the stalk, and put the controls on the wheel where they belong.
    RCO likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I would suspect the brake light switch if the cruise keeps switching off.
    RCO likes this.
  5. alanclarkeau
    7,045
    7,593
    Interesting - mine had a faulty brake light switch - but it came up in the service log, and they replaced it under warranty.
    RCO and kithmo like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Stands to reason, when you press the brake the cruise cuts off, so if the brake light switch is shorting or maladjusted then the cruise will cut off.
    RCO likes this.
  7. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Or the cruise on off switch on the cruise control stalk?
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    What happened to you? The cruise control cut off?
    Your speed must be above 30 mph, IIRC in order to set the speed. I understand it can slow down to a full stop & resume but I have never been brave enough to test that,
    kithmo and RCO like this.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    This has happened to me a few times, I don't worry about it, I assume the sensor, camera or whatever is sensing something and reacting to it. The technology seems pretty good and I'm sure it'll get better. I drive up and down the American River Canyon almost daily, my results are 200 + mpg going and 60 + returning. That's uphill for about 6 miles and at 1900 feet + in altitude. I also got 112mpg returning, once.
    #29 Andyprius1, Oct 20, 2017
  10. Andyprius1
    2,327
    859
    Cool CA
    It does do that, exactly. Try it. In the beginning I always kept my right foot perched above the brake pedal jusst in case. Now I have full confidence.
    Tyfly and RCO like this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Be brave and give it a go. I've done it quite a few times in traffic jams and it works, but initial Anderson is a bit jerky.
    Tyfly likes this.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    Your spelling correction gone wrong?
    #32 Prodigyplace, Oct 20, 2017
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Whatever you do, don't be hesitant and touch the brake or you'll cancel it and crash. You either need to brake for yourself, if you're not confident in the system, or totally let the system brake for you. It does work, albeit a bit heavy/late on the braking sometimes if you're approaching stationary traffic, but works best in slow, stop-start traffic.
    Tyfly, alanclarkeau and RCO like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Anderson ?
    Can't wait for the reply to this :ROFLMAO::ROFLMAO::ROFLMAO:
    RCO and Prodigyplace like this.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    Always bad when you typo correcting somebody else :cry:
    I was able to correct my typo.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Anderson is simply the code word for Acceleration. Why all the fuss? (n)
    kithmo, Prodigyplace and krmcg like this.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    My UK to US translation was br0ken I guess.
    kithmo likes this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    O I C :cautious:
    kithmo and Prodigyplace like this.
  19. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Good point although hopefully the AEB would save the day!
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Mitigate, if not save - depending on your velocity when disarming DRCC.
