2017 - Fuel Tank(?) Sloshing Sound
Discussion in 'Gen 4 Prius Technical Discussion' started by Purrius, Jan 23, 2026.
  1. Purrius
    Purrius Member
    172
    50
    Northeastern US
    Swapping wheels today on my roommate's 2017, and heard some fairly load sloshing sounds. Is this normal gas camel behavior?
    (Please click here if video doesn't load)
    I've never noticed it before, which doesn't necessarily mean it's abnormal, but I'd still like to ask just in case something might be secretly going cattywampus in there. :D
    52,862
    Are you sure it’s not coolant in the muffler?
    Could also possibly be air in the coolant
    #2 bisco, Jan 23, 2026
  3. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I— oh... I'm not sure.
    (But also not sure if I'm missing a joke)
    52,862
    Unfortunately, no. Check the coolant level to confirm
  5. Purrius
    Purrius Member
    172
    50
    Northeastern US
    Oh heck, okay. I'll take a look. I was about to take it out and test the new wheels/winter tires.
    Soaking of that, he's using the original lug nuts on the winter steelies. They turn down at least twelve turns, but stick out quite a bit because they're taller. Think that'll cause issues, or will it just simply look wonky? They tightened down okay and the wheels seem stable.
  6. bisco
    52,862
    they should be fine
  7. Purrius
    Purrius Member
    172
    50
    Northeastern US
    After I drove it around the block, but I'm not entirely sure how level this surface is. (It was so cold, but hopefully these will do. :censored:
  8. bisco
    52,862
    a little blurry, but looks okay?
    any water in the spare tyre area?
  9. Purrius
    Purrius Member
    172
    50
    Northeastern US
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Reference the sloshing sound, it used to be a thing back in the day for mischievous kids to dump gravel into the gas tanks of cars. Other popular adulterants were sand and more distructively sugar. My Gen 4 has limited access to the gasoline fill point, making that bit of trickery impossible. When you are ready to put gas in the car you press the fuel door release and that starts a timer which will close off the fill port. Nevermind that access is also protected by a locked fuel door. Your vehicle might have these same security features, so I'm going on about nothing.
  11. bisco
    52,862
    Tranny fluid can’t really slosh
  12. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I'll have to check again when it warms up outside. I've been inundated with tasks and got burnt out. :cry:
