2017 head gasket issues - need advice
Discussion in 'Gen 4 Prius Main Forum' started by Paprius9, Aug 12, 2022.
  1. Paprius9
    Paprius9 Junior Member
    22
    Pennsylvania
    Posted 2 months ago about a phantom engine coolant leak on my 2017 Prius 3 with 111k miles. Took it back to the dealer a second time and finally they said there appears to be coolant in one cylinder (forgot which number). I’m waiting for them to put it back together, but I have a bunch of questions. They said to start they would have to send the gasket out to the machinist for $800 to even see if that was really the issue? Or I can keep an eye on it. I brought it used, but carfax showed oil changes every 10k miles. Well cared for. So, what can be done to fix this? If left unaddressed, will it just blow someday? Over the past few weeks I’ve checked the coolant level every couple of days and added perhaps a half a cup a week. It’s getting tedious and I just want it fixed.. any chance Toyota might help?
    52,776
    certainly worth calling them and asking for goodwill warranty help.
    how many miles on her? very unusual for a gen4 to blow the head gasket.
    i would try another dealer, there are tests that can be done to determine if it is the head gasket or not, sounds like they don't have a clue.
    did you ever have it checked for the exhaust leak?
  3. Mendel Leisk
    42,264
    Might be, but might also be coolant leak in exhaust heat recovery system. That is common with 4th gen; head gasket is not.
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    It’s not clear to me why they’d do that: the cylinder head gasket, part number 11115-37071 (formerly 11115-37070) is a non-reusable part, and if it’s removed for any reason, you just throw it away and install a new one, list price $66.72.
    If they remove the cylinder head, to get to the gasket, they should inspect the head for warpage and cracks and inspect the cylinder block for warpage. Those are tasks any mechanic should be able to do using a precision straightedge, feeler gauge, and dye penetrant, as the Repair Manual (more info) instructs; it’s hardly work that requires specialized equipment or a machine shop.
    That would account for the missing coolant, but not for finding it in one of the cylinders. As @bisco suggests, has anyone done a compression test?
  5. texasdiver
    texasdiver Member
    68
    114
    Vancouver WA
    Four Touring
    I expect the $800 is for machining the cylinder head not the head gasket. Some shops automatically do this with any head gasket repair. If you are going to tear that far into the engine you might as well make dang positive you won't have any head gasket problems in the future.
    But again, make DANG sure the problem is the head gasket and not the heat exchanger. I had a shop diagnose a blown head gasket on my 2016 and it turned out to be the heat exchanger which was a DIY $10 repair by me to bypass it. Car has run perfectly since then. Here's the thread on my car: 4th Gen DIY heat exchanger bypass solution | PriusChat
    amos, mikey_t, jerrymildred and 2 others like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,003
    6,894
    Texas Hill Country
    First thing to do is to ask them for a written quote on what they recommend. Pretty sure there was miscommunication between you and the service adviser. Often the adviser has never been a mechanic and is just trying to tell you what his mechanic told him.
    To be clear, no one will remove a cylinder head to check anything for $800. It is a $2,000 - $3,500 job to take it apart and put it back together again. They have to change the gasket if they tear it down that far. Timing chain and many accessories are removed and carefully reinstalled. Be sure what is being suggested.
    Doug McC and Elektroingenieur like this.
  7. Mendel Leisk
    42,264
    ^ This, this, and this…
    Doug McC and 2010moneypit? like this.
  8. texasdiver
    texasdiver Member
    68
    114
    Vancouver WA
    Four Touring
    Had I not intervened they would have torn apart the engine and given me an unnecessary $4,000 head gasket replacement that would not have fixed the problem. The only thing that worked in my favor was that their Prius guy was behind on the work schedule and didn't get the parts ordered on time so I caught the issue while the car was still sitting in their lot and not completely torn apart.
    amos, dacoobob and 2010moneypit? like this.
  9. texasdiver
    texasdiver Member
    68
    114
    Vancouver WA
    Four Touring
    I expect the $800 was just to resurface the cylinder head by an outside machine shop. That sounds about like what an outside machine shop would charge for that job. All the other parts and labor by the shop doing the repair work would be on top of that obviously and will likely exceed $4000 all in. Tearing down a head on a modern car is an enormous task.
  10. Paprius9
    22
    Pennsylvania
    Thanks everyone. So yes, the 800 was just the start and would require taking the engine apart. Thousands then. The tech isn't even 100 percent sure that's the issue. I just called the service advisor and told them to make certain it's not the heat exchanger.
  11. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Check the heat exchanger as others have said. Very easy to bypass to test to see if the coolant usage goes away. If you were not able to do it I don’t see any shop charging anymore than an hour and five to $10 for the part. Really only takes a few minutes to do.
  12. Paprius9
    22
    Pennsylvania
    Well, they said it's ready to pick up. It's not the heat exchanger they said - they checked the EGR valve. Had it under pressure for a few days. No leaks. Guess I'm back at square one. Perhaps I can take it to an independent shop and do the bypass..
  13. 2010moneypit?
    314
    122
    Beaumont ca
    It is my understanding that the EGR and heat exchanger are different systems. So if they tested the EGR and it passed that’s great but they did not test the heat exchanger.. The way I would test the heat exchanger would be to bypass it and see if the coolant loss still occurs.
    jerrymildred and Jburner like this.
  14. Jburner
    Jburner Member
    68
    44
    Wisconsin
    ^^^ This! ^^^^^ Seems premature for headgasket at 100k
    dacoobob likes this.
  15. rjparker
    11,003
    6,894
    Texas Hill Country
    Losing coolant is not normal and you can go five years without ever adding more. So take it seriously if its more than a small amount of expansion and contraction. Half a cup a week is too much. Cold level should equal cold level. It only takes one overheat and an extra mile of driving to cause engine problems.
    One thing you find out is all of the guys at a dealer are not the sharpest knives in the drawer when it comes to things they have not seen before. Including the service advisers. Often the sharpest end up in their own shop which may be small but either specializes in Toyota, hybrids or perhaps is just a clean well organized operation. It's not always great to tell a shop your diagnosis other than suggesting "I don't know but an internet guy thinks.." Being in Washington State, you should be able to find the right shop.
    #15 rjparker, Aug 15, 2022
    Mukunda, jerrymildred and dacoobob like this.
  16. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    my Toyota dealership tried to tell me i had a bad head gasket in my 2016. i took it to a private shop for a second opinion and they immediately figured out that the head gasket was fine, my leak was at the exhaust heat exchanger (just like every other Gen 4 apparently). don't trust the dealership diagnosis.
    jerrymildred and bisco like this.
  17. bisco
    52,776
    call toyota corporate
    2010moneypit? likes this.
  18. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    Find a more competent dealer or independent shop that specializes in hybrids.
  19. TinyTim
    TinyTim Active Member
    414
    241
    Seattle
    I think I can diagnose the problem for you. You were going to get rolled for thousands. My charge to you is peace of mind. Kindly tell them they will never see you again.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Oh my!! They really are clueless, aren't they! The EGR system has nothing to do with the heat exchange system back at the catalytic converter that's causing problems for you and other Gen 4 owners.
    mikey_t likes this.
