2017 hubcaps look like….
Discussion in 'Gen 4 Prius Main Forum' started by dmh1026, Dec 29, 2021.
  1. dmh1026
    dmh1026 Junior Member
    25
    Estero, FL
    Four Touring
    I have 2017 touring 4. Hubcaps look like garbage and I still have the peeling rear quarter panels. Thanks Toyota!
  2. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    You can wrap your rear quarters and next time you need tires you could try to get a set of used 15' wheels. 15's will give you a better ride, a bit more MPG's and tires are less expensive.
  3. dmh1026
    25
    Estero, FL
    Four Touring
    I had a 2011, and a 2015 with 15” rims. I like the 17’s better. The silver inserts suck. All 4 look like that. I might order the black ones and change them out. I talked with someone about wrapping the 1/4 panels and they told me it won’t look good due to the peeling of the coating. Won’t be smooth.
  4. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    That sucks. I haven't had the peeling issue yet on my 16. Just curious do you happen to use one of those automated car washes often? I'm also in SW Florida. Hopefully she's reliable which is why most of us bought into the Prius anyway.
  5. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    No issue with peeling on my 2017 either and I really like the design.
    dmh1026 likes this.
  6. dmh1026
    25
    Estero, FL
    Four Touring
    I never use car washes. Mine gets hand washed only. The sun is brutal on the back side panels. I’ve seen several peeling away like mine have.
  7. Mendel Leisk
    42,310
    It's not just the wheels making the difference. In fact, they might have little effect. The third gen touring model has differences in the suspension and steering. I'm not sure of the details; do know the turning radius is increased. And have test drive both: touring felt "better".
    That's us, and when I change to 15" Michelin X-Ice wheels in winter, the feeling doesn't change.
  8. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    Do you go to drive automatic car wasshes? They use really high acidic wheel cleaners
  9. dmh1026
    25
    Estero, FL
    Four Touring
    No. Hand washes only.
