2017 parking sensor repair problem
Discussion in 'Gen 4 Prius Audio and Electronics' started by shermankrokodyl, Sep 11, 2023.
  1. shermankrokodyl
    shermankrokodyl New Member
    Warsaw, Poland
    I own a Toyota Prius with six parking sensors front and rear. During an accident, the front far right sensor was damaged. Only three cables are left from the sensor harness. I purchased a new sensor with a plug but have no idea how to connect the cables because they are different colors. Can I download a parking sensor installation scheme for my prius somewhere?
    52,822
    techinfo.toyota.com
  3. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    when I had an accident with my 2016 Prius Four with parking sensors the sensors themselves were mostly plug-and-play but when they didn't work after i got it back from the body shop they had to go back and replace the wiring harness. If you're at that step as well be aware you're going to have to calibrate the sensors and that's a 2-3 hour process usually done at the dealership. If your plan is to fully go DIY then you should buy a 1month subscription to the repair manual.
  4. shermankrokodyl
    Warsaw, Poland
    Okey, so i must buy subscription to get wirings diagrams. They are not any chance to get it for free?
    I would like to buy wiring harness, but I repair my car in Poland and access to a used one is very expensive. It costs $600 at the Toyota store so i try to DIY
  5. shermankrokodyl
    Warsaw, Poland
  6. bisco
    52,822
    RojaRosie likes this.
