2017 Plus not charging
Discussion in 'Prime Main Forum (2017-2022)' started by MikeDee, Feb 17, 2023.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    It is NOT the EVSE or electrical outlet. The dealer verified with one of their own EVSEs first thing when I dropped it off this morning. I'll know more this afternoon.
  2. MikeDee
    1,581
    597
    I think I noticed two pins symmetrical to each other that were pushed back an equal amount. Both pins were still out a good amount (not pushed all the way back). My first thought was that was normal but maybe not. Do you have a link to the posting for that?
    #22 MikeDee, Feb 20, 2023
  3. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Hi , in the J1772 connector there is a pin that carry a function named Control Pilot
    "Control Pilot" is a communication line used to signal charging level between the car and the EVSE, and can be manipulated by vehicle to initiate charging as well as other information.The signal is a 1 kHz square wave at ±12 volts generated by the EVSE to detect the presence of the vehicle, communicate the maximum allowable charging current, and control charging begin/end.
    Dialog between the car Charger and the EVSE looks to be non present.
    #23 Louis19, Feb 20, 2023
  4. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    There are five pins. Pretty sure the two big ones are for current, then there are three that look like (as noted above) they are used for sensing.
    More to the point, at 12V, even a bit of crap in there (dust bunny, leaf fragment, dead spider) might be enough to interrupt communications.
    Plus, those long thin tiny pins look like they are just begging to be broken. I mean, this is a good design and all. But stuff happens.
    Beyond this, I know nothing. Here's how mine look. I'm sure there must be a better diagram on line somewhere.
    Edit Looking at an on-line diagram, those pins are, top to bottom, left to right:
    Power Power
    "Safety" Ground "Communication"
    Others label the bottom row:
    "Control pilot" Ground "Proximity pilot"
    From Versinetic: https://www.versinetic.com/news-blog/ev-charging-connector-types-guide/
    • The proximity pilot (PP) pin tells the charging equipment the type of cable connected to the socket – different cable thicknesses can cope with different amounts of electrical current
    • The control pilot (CP) pin provides bi-directional communications between the electric vehicle and charging system. This checks the maximum amount of current that the EV is able to take at any one time.
    Doesn't matter. Pretty sure if any one of those is busted, it won't work.
    Shine a light down the ends of your two charger cables and see if maybe you see a little gleam of copper in the "Proximity pilot" or "Control Pilot" holes.
    #24 chogan2, Feb 20, 2023
    Louis19 likes this.
  5. MikeDee
    1,581
    597
    I don't think there's a communication problem between the EVSE and the car. When I plug in the EVSE, the charge indicator lights solid yellow. When I start a charge now, that light flashes indicating current flow, but charging shuts down after 5-10 seconds. The green light on the car, which was solid green indicating the car is charging, flashes rapidly, then turns off, indicating a fault. The EVSE charge indicator goes back to a solid yellow. If there was a communication problem, the EVSE wouldn't even indicate a connection to the car. I could be wrong obviously, but I don't think the charge port is at fault here.
  6. Gokhan
    Gokhan Senior Member
    6,708
    2,659
    Paramount CA
    If it is the plug, it should be a cheap fix. I always push mine in very gently.
  7. MikeDee
    1,581
    597
    It's the charger assembly. Covered under warranty but 2 weeks to get the part. A $2000 part.
    #27 MikeDee, Feb 20, 2023
    bisco, Louis19 and Gokhan like this.
  8. Gokhan
    6,708
    2,659
    Paramount CA
    Blame it on the Leviton EVSE. ;)
    Many use the OEM EVSE with a cheap plug adapter to connect it to a 240-V outlet. It is 2.9 kW (12 A) as opposed to around 3.2–3.3 kW on a ChargePoint Level 2 EVSE, but it works.
    #28 Gokhan, Feb 20, 2023
  9. MikeDee
    1,581
    597
    No, I don't believe that at all. It's a quality product, UL listed. Might be US made, but not positive. Look it up. Leviton doesn't make cheap junk.
    #29 MikeDee, Feb 20, 2023
    Gokhan likes this.
  10. MikeDee
    1,581
    597
    Doesn't Bisco use one of these? Didn't seem to fry his vehicle.
    iPhone ? Pro
    Gokhan likes this.
  11. bisco
    52,804
    i don't, but in the threads where lots of people do, i haven't seen any problems
    MikeDee and Gokhan like this.
  12. MikeDee
    1,581
    597
    I looked at my charging port with a flashlight. No pushed back or bent pins. Everything looks clean.
  13. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Just to clarify, the charger is in the car. The lump on the charge cable is the EVSE, electric vehicle supply equipment, or charging station. It is a smart power supply that communicates with the car's charger, as mentioned above. Without communication you got nothing.
  14. MikeDee
    1,581
    597
    That's right. I hope when they do the actual work, it doesn't turn out to be Minoks chewing on the power cables. (That's an old Star Wars reference, for the uninitiated.)
  15. Washingtonian
    Washingtonian Senior Member
    726
    621
    I was wondering why it was still under warranty after 6 years, but I looked it up in the manual. It is part of the hybrid system and is warranted for 96 months or 100K miles.
  16. MikeDee
    1,581
    597
    The car has been fixed. Charger assembly was replace under warranty, no charge to me.
  17. bisco
    52,804
    congrats!
    interestingly, pip had a bad run of chargers in the later years.
    MikeDee likes this.
