2017 Prime headlight failure
Discussion in 'Prime Main Forum (2017-2022)' started by ForestBeekeeper, Mar 11, 2025.
  1. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    My left-side headlamp began flickering and intermittently going dark this past November. When it goes dark it triggers the check engine light. When I turn the headlights off the error code seems to reset.
    Beginning in March the check engine light comes on every time the headlights are turned on.
    I took it to our dealership to get some idea of what was wrong.
    On 8 March 2025 the dealership says that I need to replace the headlight assembly and its computer. The assembly costs $1700 and the computer $200. With projected labor fees the total cost will be $2700.
    For a failing head light, or I assume a loose connection [since it has been an intermittent failure]. This appears to be an extremely out of proportion remedy.
    52,891
    This is how Toyota has evolved. Even gen 2 had some messed up lights iirc.
    It’s likely that all manufacturers are following this model to keep manufacturing costs down.
    Pay me now, or…
    ForestBeekeeper likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    IMHO; at that price I'd start looking online for a left headlamp assembly and replace it yourself. Re: the computer; is that integrated into that headlamp or does it control both? While it's just $200 bucks, you may be able to find one and try replacing that first?
    Good Luck.
