2017 Prime - where to find strut tower bar
Discussion in 'Prime Accessories and Modifications' started by Thomas O'Connor, Jan 11, 2021.
  1. Thomas O'Connor
    Thomas O'Connor New Member
    Los Angeles
    I'm looking to buy a strut tower bar that fits a 2017 Prime - who sells one?
  2. Tideland Prius
    16,673
    You could also look for the Gen 4 as the width between the front strut towers should be identical.
    If @HAWAIIANBUILT is still around, he could point you to a place.
  3. Thomas O'Connor
    Los Angeles
    I emailed Cusco and they said it is difficult to put a strut tower bar on because of minimal amount of room
  4. Thomas O'Connor
    Los Angeles
    Anyone use this type of bar before? it doesnt go directly over the struts, not sure how well it works?
  5. Tideland Prius
    16,673
    Those look more like body braces.
    You can go with MEG@TW stabiliser bars if you want bracing (It's underbody braces) instead of tower braces.
  6. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I have a 2019 non-Prime. I have the Cusco "strut" bar. I don't know why they call it that since it doesn't connect to the struts at all. If you want to get a real strut bar, I believe only Hardrace makes one. I have the Hardrace strut bar on my car as well (ignore the Cusco logos on the upper and lower bar. Had extra stickers and threw them on). Bottom brace is a Hardrace radiator brace 20200207_183255.jpeg 20200207_183111.jpeg
    Tideland Prius likes this.
  7. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    no one sells one.
    the mounting points are physically there but there are some major differences between the headlight assembly locations.
    I purchased a set for the non prime model and had to cut and reweld the brackets as well as trim them to fit under the LED headlights.
  8. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    That radiator and upper brace make any difference?
  9. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
  10. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
  11. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    Did you get the engine chassis brace or the strut tower brace? I want to get the strut tower brace. Just seeing how much I have to cut and weld.
  12. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
