2017 Prius 2 USB port not working to charge cell phone?
Discussion in 'Gen 4 Prius Audio and Electronics' started by Manjunath, Sep 17, 2017.
  1. Manjunath
    Manjunath New Member
    PA
    How do i fix this problem?
    2017 Prius 2 USB port not working to charge my cell phone
  2. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I think you need to provide more information.
    iPhone ?
  3. alanclarkeau
    alanclarkeau Senior Member
    6,794
    7,360
    near Brisbane, Australia
    Like most USB ports, it's mostly there as an audio output. As such it will probably have a MAX ½ amp charging capacity, which will barely charge a phone, if at all, depending on the phone, the signal strength and what load it is under..
    Get a 12V charging adaptor.
  4. ATHiker
    ATHiker Senior Member
    624
    549
    Massachusetts
    Four Touring
    I cannot speak to your issue as I have never tried to charge my phone iPhone that way.
    FWIW, I charge from the cigarette lighter socket (with a very cheap USB adapter) provided for the backseat passengers. Not the one on the top of the console.
    I leave the 3-foot cable in all the time; easier to find and manage than one going into the Prius USB port (which holds my flash drive with my music files).
    Montgomery and RCO like this.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,698
    11,284
    Central Virginia
    There is also a socket up front.
    Montgomery likes this.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,012
    2017 Prius c
    THIS.
    Or if you are stubborn......take it to a dealer for a warranty visit so they can tell you the same thing.
    BostonREd1 and alanclarkeau like this.
  7. nategold
    nategold Member
    117
    38
    Arlington, MA
    Not true. Charges iPhone 6S just fine, and quickly. Puts out at least 1A.
  8. alanclarkeau
    6,794
    7,360
    OK, sorry - I didn't realise it was a USB 3.0 port.
    It was reported on a couple of posts last year that it was only a 2.0 port.
    I wonder why my SAMSUNG charges very slowly if at all (I turn GPS, Bluetooth, WiFi off to get it to charge in the car).
  9. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    270
    Harrisburg, PA
    On my Gen 4 it's a USB 2.0 port per the Owner's Manual page 452
    alanclarkeau, RCO and Prodigyplace like this.
  10. MikeDee
    MikeDee Senior Member
    1,187
    439
    San Francisco Bay Area
    It is USB 2, but puts out 1 amp (I've measured it). Obviously, the port doesn't follow standards.
    When I had an android phone I remember having to use either a special charge cable or a change to a setting to enable higher current charging, but that was a number of years ago.
  11. Prodigyplace
    11,698
    11,284
    Central Virginia
    USB 2.0 specification only requires a minimum of 500 mA. It does not meet the USB 2.0 Power delivery specification, but Toyota does not claim that. There are 12 volt ports & Qi charger expected to be used for charging. The USB port is for audio & data.
    pilotgrrl, RCO and alanclarkeau like this.
  12. RCO
    RCO Senior Member
    3,709
    5,176
    Cornwall
    Somebody should make a sticky for this old chestnut, in red and underlined! :rolleyes:
    MLK43611, pilotgrrl and alanclarkeau like this.
  13. RCO
    RCO Senior Member
    3,709
    5,176
    Cornwall
    Total change of subject, but it's anybody else getting lots of unexpected database errors today. It's getting really irritating!!! :mad:
  14. Prodigyplace
    11,698
    11,284
    Central Virginia
    You are really unlikeable today. Once it took me 4 times to like one of your posts.:(:rolleyes::sick:
    Database errors too, earlier.
    RCO likes this.
  15. Sam Spade
    2,036
    1,012
    2017 Prius c
    Let's see......you have been a member here for over a year now.
    And it hasn't sunk in yet that this IS A CONTINUING AND UNENDING PROBLEM ?????
    AND that there are at least a half dozen other threads discussing it, with a couple of them currently active ????
    It does nothing useful to shotgun complaints about it into other threads.
    RCO likes this.
  16. RCO
    RCO Senior Member
    3,709
    5,176
    Cornwall
    LOL, so my wife says!
    Sorry you were offended, Sam. I did post on those other threads but not sure they were reaching their target and you certainly don't seem to have read them. Maybe one of us should lighten up a bit.
  17. Prodigyplace
    11,698
    11,284
    Central Virginia
    I have found the site a lot lighter since I put that person on my ignore list. It sometimes makes things confusing when somebody responds to a post you do not see.
    I periodically look at ignored posts but this person stays on my list for now.
    RCO likes this.
  18. pilotgrrl
    pilotgrrl Senior Member
    889
    1,794
    Chicagoan in TX
    Vehicle makers do not provide Qualcomm QuickCharge compliant USB ports.
    Buy the appropriate certified QuickCharge adapter. Anker and Aukey are reliable products I've used.
    We get complaints about this all the time.
  19. Prodigyplace
    11,698
    11,284
    Central Virginia
    Young people think of USB (Universal Serial Bus) as a charging standard. It was a data standard until Apple (ab)used the connector and designed a charger that was backward compatible with USB devices. The rest is history.
    Older people remember RS232 & other serial standards that were replaced by USB.
    desulliv, pilotgrrl and RCO like this.
  20. RCO
    RCO Senior Member
    3,709
    5,176
    Cornwall
    I've never blocked Sam and occasionally agreed with him on some things. We can all go off at half-cock occasionally and I'm not perfect.
    NB: half-cock originates from the ancient flintlock gun firing mechanism which have a misfire if the trigger was released over the short draw distance. It's nothing to do with sex or the male chicken.
    Groan, LPT1 and LPT2
    #20 RCO, Oct 25, 2017
    pilotgrrl and Prodigyplace like this.
Loading...
