2017 Prius 3rd Dashboard rattle noise
Discussion in 'Gen 3 Prius Main Forum' started by David77, Jun 14, 2017.
  1. Toyota should be recall?
    50.0%
  2. Dealer should be fix right
    50.0%
Multiple votes are allowed.
  1. David77
    David77 New Member
    Los Angeles
    I bought the 2017 Prius 3rd Gen on May 2017. The thing is when I driving on rough road or bump road then coming noise from dashboard area. It really bother me so I made appointment to dealer Puentehills Toyota Service Agent Mark Fetterman. So I went there road test with one of service supervisor Donny and I we catch the noise from around dashboard. So they took care of it. I read service discription they put insulation cover up. I'm so happy. I thought they fix problem... but after couple days later it sounds again again.. I'm so sad and it bother a lot. Has anyone else had this problem?
    #1 David77, Jun 14, 2017
    @india likes this.
    52,876
    welcome!
    i thought i just saw a tsb thread for it. i'll look around.
    edit: you're in the wrong forum. check the stickies in the gen 4 main forum, it's the top one.
    #2 bisco, Jun 14, 2017
  3. David77
    David77 New Member
    Los Angeles
    Thank you for your advice.
    T
  4. Chuck Abbe
    Chuck Abbe New Member
    Bakersfield, CA
  5. Chuck Abbe
    Bakersfield, CA
    I have had the same problem. I have taken it in twice to the dealer and both times they wrapped some foam around some loose part. Both times the rattle disappeared, but only for a short time. Now it is back again! I otherwise love the car, but this rattle is about to drive the wife and I around the bend.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Let me go outside and check my 2012 to see if I have the same problem.
