2017 prius 4 intake manifold hoses connections
Discussion in 'Gen 4 Prius Technical Discussion' started by Hovhannes, Apr 23, 2023.
  1. Hovhannes
    Hovhannes New Member
    Glendale
    Please can anyone provide me with the picture or diagram of all the hoses going out from intake manifold of 2017 prius 4.
  2. Elektroingenieur
    2,515
    3,253
    Three Touring
    The best diagrams are in the Repair Manual (more info), in the topics under Engine/Hybrid System: 2ZR-FXE (Intake/Exhaust): Intake System, but you can also see the various connections in the parts catalog illustrations:
    Figure 12-01, Ventilation Hose
    Ventilation hose: PNC 12261
    Figure 16-03, Radiator & Water Outlet
    (Click View more images, and then select the second image)
    Water by-pass hose: PNC 16261
    No. 2 water by-pass hose: PNC 16264
    (These are connected to the throttle body assembly, not to the intake manifold.)
    Figure 17-08, Vacuum Piping
    No. 2 fuel vapor feed hose: PNC 23827A
    Figure 22-11, Fuel Injection System
    Throttle body assembly: PNC 22210
    Figure 25-01, Exhaust Gas Recirculation System
    EGR pipe assembly: PNC 25610
    Figure 84-04, Electronic Fuel Injection System
    E.F.I. vacuum sensor assembly (MAP sensor) with vacuum hose: PNC 89421​
  3. Hovhannes
    Glendale
    Thank you,
    I've one more question about the 2017 prius gas engine water pump, where I can find circuit diagram of that pump?
