2017 Prius C 6.1in Touch Screen Resolution
Discussion in 'Prius c Audio and Electronics' started by Fox-Alice, Apr 23, 2021.
  1. Fox-Alice
    Fox-Alice New Member
    Austin
    2017 Prius c
    Hi all,
    I have a 2017 Prius C Three and am wanting to change the startup and display off images correctly/with the proper size to fit the screen. I have them on there and can change the images easily, however, I can't seem to find what the resolution in pixels is to get the correct aspect ratio and have the image display on the entire screen with no black gaps.
    I've googled and have found brochures, but nowhere lists the actual pixel resolution.
    So, what is it?
    Thanks
    _a
  2. Tideland Prius
    16,627
    Usually they're VGA (640x480)
    Fox-Alice likes this.
  3. Fox-Alice
    Austin
    2017 Prius c
    Hey~!
    Thanks for the reply, but I tried it and there are large gaps on the left and right.
    I have it at 768x480 and that seems to be as close(or it may be correct) I can get.
    There are still two black/blank space gaps on the sides at that resolution, but it's almost the entire screen—which could be that is the correct resolution and the screen just has those gaps by default.
    Tideland Prius likes this.
  4. Tideland Prius
    16,627
    Nice!
    try 885x530. I found that resolution suggestion on a Tundra forum.
  5. topshot
    topshot Member
    150
    57
    Midwest
    2015 Prius c
    I wasn't aware this was something we could do (though not too surprised). Where is the documentation for that? Done through TechStream?
  6. Fox-Alice
    Austin
    2017 Prius c
    This worked perfectly, thank you!
    This is the post I found on this forum that details what you need to do: How to customize the Splash Screen | PriusChat
    Here is the rundown regardless: "The Image has to be a JPG or JPEG image up to 10MB. On your home PC, you create TWO files on a USB thumb drive, one called "StartupImage" and "DisplayOffImage" (Both Case sensitive). You put the files (images) that you want, inside the "StartupImage" folder. You then go to your Prius and plug into the USB port. You then go into Setup -> General -> Customize Startup Image."
    Your thumb drive will need to be formatted as FAT32—which is easy to do if you look up how depending on your computer's OS(Mac, Linux, Windows).
    Pri3C, Tideland Prius and topshot like this.
