2017 Prius Coolant Capacity
Discussion in 'Gen 4 Prius Main Forum' started by Shujayet, Aug 5, 2022.
  1. Shujayet
    Shujayet New Member
    New York
    Hello,
    I have a 2017 Prius Two with 110k miles on it, never changed the coolant. How many gallons of Toyota 50/50 mixed coolant do I need to fill both the engine and inverter coolant?
    Thank you!
  2. Mendel Leisk
    42,355
    Two US gallon bottles will do. Here's the spec'd capacities from Owner's Manual (page 732), though I suspect the drained quantity will be less:
    alanclarkeau likes this.
  3. Shujayet
    Shujayet New Member
    New York
    Thank you!
    I bought two gallon of Toyota coolant but the independent mechanix said it may take three.
    That’s why I got confused.
  4. Jburner
    Jburner Member
    68
    44
    Wisconsin
    No way it takes 3. I barely used 1 when I did mine, but that's probably because I didn't remove the heat exchanger hose underneath. And yes, I followed the instructions noted above. I did it at 100K and the coolant that I took out was the same color that I put in. I definitely could have gone longer.
    Shujayet likes this.
  5. CT415
    CT415 Junior Member
    17
    thank you!
