2017 Prius Coolant Change
Discussion in 'Gen 4 Prius Main Forum' started by Shujayet, Aug 10, 2022.
  1. Shujayet
    Shujayet New Member
    New York
    Hello,
    I just changed my 2017 Prius’ hybrid inverter and engine coolant. In the engine coolant, there is a portion(see the attached photos & look for the cicrled area) it is empty. Although the coolant is on full mark, that small area is empty. Is it normal or should I open that tuny plug and fill it up?
    Thank you!
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    It is the same for the coolant overflow tank for the radiator. I think it is normal. As long as it still reads in between low and full, you'll be fine.
  3. Shujayet
    Shujayet New Member
    New York
    Okay.
    Thank you. It reads a bit higher than FULL for both the engine and hybrid system coolant tanks.
  4. Jburner
    Jburner Member
    68
    44
    Wisconsin
    Need to read between low and full (high). There needs to be room in the tank for expansion of the fluid when it heats up.
  5. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    What is there need to be room on the top for expansion when there's an overflow port
  6. Jburner
    Jburner Member
    68
    44
    Wisconsin
    Because when the fluid shrinks after cooling, you would have less in the reservoir if they didn’t have the expansion area inside the sealed tank. And because that’s how they manufactured it, I guess. :)
    #6 Jburner, Aug 11, 2022
  7. Shujayet
    Shujayet New Member
    New York
    Should I get rid of that little bit excess coolant and let it be?
  8. Jburner
    Jburner Member
    68
    44
    Wisconsin
    Just leave it. I will be fine. It will either be expelled via the overflow or you'll just have extra. Won't hurt anything.
