2017 Prius no coolant
Discussion in 'Gen 4 Prius Main Forum' started by shadow4478, Sep 24, 2022.
  1. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    As temps are getting cool, I noticed we had no heat at all, looked at the coolant level and there was nothing there no pink visible at all. I never got a low coolant notification odd, I will top it off but we have been possibly driving like this all summer. who knows if more damages have been done. I guess this afternoon I will know better after I see how much fluid it takes.
  2. JC91006
    16,936
    8,647
    How many miles are on your car? Are you the 1st owner?
    Coolant just doesn't disappear, you should check for leaks
    52,862
    there have been reports of leaking coolant from the exhaust heat exchanger.
    if you never got a temp light, hopefully it is just low
  4. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    I had same issue back in January - leak inside the catalytic converter - had to be replaced - $$$2100 - but they can be very hard to find. Lots of threads on this.
    douglasjre likes this.
  5. Mendel Leisk
    42,352
    IIRC dealerships will replace what’s needed for free, authorized by Toyota. Dealerships have been misdiagnosing as head gasket failure too, so tread carefully.
  6. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Probably this...
  7. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    It’s a 2017 with 129555 km
    I managed to put in the entire jug of slid in 3.7l or about a gallon. Heat did come back in after a few too ups, but there is clearly some issue. Now the exhaust it smoking like someone did a burnout on a muscle car. It’s mixing somehow with the exhaust. Engine oil if fine no foaming.
    it looks like the bulletin is up to 80/miles which I’m past by ~ 1000km
  8. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I'd call Toyota corporate to get override
  9. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    You can do that ? Also not sure it even applies to Canada
  10. Jburner
    Jburner Member
    68
    44
    Wisconsin
    Those symptoms indicate almost certainly that it’s the exhaust heat exchanger keep an eye on that reservoir and don’t drive it too long without refilling. It can be bypassed if needed. There are several threads on this.
    Do report this to Toyota. In my opinion, they need to extend this to 150k or 10 years. It’s not a small function and very expensive to fix if going with OEM for the part alone.
    This hose will work in a pinch without any lights or modifications if you are up to the rather easy task. https://www.amazon.com/gp/aw/d/B000C2U8Q2/ref=ox_sc_saved_image_5?smid=ATVPDKIKX0DER&psc=1
    Mendel Leisk and FuelMiser like this.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Even if Toyota will cover the catalytic converter (heat exchanger), there's a supply chain issue and they aren't readily available; so, if you need to drive your car regularly, I'd order the U-shaped coolant hose from Amazon and perform the bypass. It can always be reversed if you do come across a new catalytic convert with the heat exchanger.
  12. Mendel Leisk
    42,352
    It’s been reported here, dealership service departments won’t install a bypass; it’d “compromise pollution controls”. I guess their hands are tied, but I’d suspect they could get a permission, with a little bit of effort, considering the supply issues, and the consequence of bricked cars.
  13. douglasjre
    2,250
    751
    Null, NL
    Bypass hose is a really creative workaround. I wonder how much that will effect warm up time In cold versus hot climates....
  14. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    I had mine bypassed while waiting for the new part to come in on backorder (private shop not dealership). A delay in warmup was noticeable but not a big deal
  15. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    Update: it was the heat exchanger
    Vehicle had 129980km when Parker the dealer warranty goes to 130k they fixed it no charge
    Aparently it’s an expensive repair.
  16. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    And there was no wait no supply chain issue parts readily available as per dealer.
  17. Mendel Leisk
    42,352
    Parker? Clarify? Earlier you said coverage was only to 80k, that changed, was waived?
  18. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    Typo “parked” it was 80k miles which is under 130k but here Toyota Canada rounds up to 130k km
  19. Jburner
    Jburner Member
    68
    44
    Wisconsin
    That sure would be nice if that was extended to 150k or 10 yr along with the hybrid battery. I can dream… . Hope I won’t have to do either.
