2017 prius prime headlights
Discussion in 'Prime Main Forum (2017-2022)' started by Hodatch, May 23, 2018.
  1. Hodatch
    Hodatch Junior Member
    26
    16
    2024 Prius Prime
    I must not be searching hard enough, but what kind of bulbs go into the 2017 prius prime headlight??
    Has anyone's headlights burned out?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I might be wrong, but I thought all Prime trims came with LED headlights that are not really replaceable unless whole assembly is swapped but very, very expensive. They do not burn out like older halogen bulbs, and last for the life of car?
    Hodatch likes this.
  3. Hodatch
    26
    16
    2024 Prius Prime
    I've done alot of research, and I think ur right. No bulbs, but the whole assembly. And the assembly is $1200 dollars a side! This is crazy.
  4. Salamander_King
    11,024
    8,970
    New England
    Unless you have an accident or something, you should not have to replace it. Is your headlight out? If it is, it should be covered by warranty still. Hopefully, I don't have to replace mine ever.
  5. Erik Owens
    Erik Owens Member
    162
    59
    There might be codes associated with the headlights if the No 1 headlight ECU is out. Of course you could be correct in the headlight assembly is bad itself but the LED lights are designed to last a long time. Plus since they are duty cycled to illuminate, your dealer may want to keep it more than a few hours since getting to any of it is behind the bumper,...that is full of sonar sensors, radar cruise, grill shutter etc.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I do not think he said he has any issues, I think he is just trolling to generate hate and discontent.
    "After about 6 12volt batteries and 2 HV Batteries, our headlights might fail! Oh No!"
    FuelMiser likes this.
  7. Tideland Prius
    16,623
    They are LEDs and are supposed to last the life of the vehicle.
    Also, $1,200 is much lower than the original cost when it first debuted on the LS600h L (they were US$5,000 a piece).
    Of course, they're still higher than a regular halogen headlight assembly (What do those go for? a couple of hundred dollars? $200-$400 for a Gen 3 Prius halogen assembly?)
  8. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    ...... that's what they say about the Macbook Pro keyboard
  9. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    #9 heiwa, May 26, 2018
  10. mczouav
    mczouav Member
    BE
    Has anyone experienced slow up shifting of a prius prime headlight. I mean the adjustment of the level of the focussed beam. It have readjusted it several times in the last 6 months and now it reached the end of the screw and won t adjust anymore. I ll investigate this week end... But it s really annoying to flash everyone including airplanes at night!
    Ps: no accidents or shocks to the headlight in question.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I wonder if there's something wrong with the leveling sensor. I don't know yet where it is in the Prime, but in the Gen 2 it's under the deck in the hatch area toward the left side.
  12. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Do Primes even have level sensors/adjustable headlights? Usually such headlights move during startup, and I don't recall it with mine.
  13. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    Prius Prime sold in EU have Matrix LED headlights and auto-levelling system.
  14. smyles
    332
    229
    US
    2020 Prius Prime
    /never mind/
  15. mczouav
    mczouav Member
    BE
    Everything is possible with technology...
  16. Mendel Leisk
    41,956
    You might be right, not seeing bulbs here:
    Headlamp Components for 2017 Toyota Prius Prime | Toyota Parts
    So basically, a one grand "sealed beam"? :confused:
    Our third gen Touring has LED's. Might be the same story, albeit "only" about $600:
    Headlamp Components for 2010 Toyota Prius | Toyota Parts
    #16 Mendel Leisk, Feb 5, 2020
    Salamander_King likes this.
  17. Trollbait
    12,693
    Well, there is a difference. You should only need a replacement if the car is in an accident. So the one grand times two isn't part of regular maintenance.
  18. Salamander_King
    11,024
    8,970
    New England
    I have seen on Japanese Prius PHV video that the LED head light lens can be replaced. IIRC, apparently Toyota has a part number for the lens only for the headlight, but not LED part. Can't remember how much it was, but substantially less than whole LED headlight assembly.
  19. Mendel Leisk
    41,956
    Well that's what I'm wondering; do the LED "bulbs" never fail? From our 3rd gen Owner's Manual:
  20. smyles
    332
    229
    US
    2020 Prius Prime
    well, have you ever baked a headlight?
