2017 Prius Prime Needs New Tires....finally
Discussion in 'Prime Main Forum (2017-2022)' started by shebobg, May 21, 2022.
  1. shebobg
    shebobg Junior Member
    46
    Woolwich Township, NJ
    I have a 2017 Prius Prime that up until now didn't need new tires. I now need to purchase some and I have read what everybody also mentioned on this site but am still confused. I live in NJ so I need something that can handle snow and rain but that the snow part isn't that big a deal since I'm a senior and don't like to travel in snowy weather. I don't really care about the noise but want safe in wet weather (rain) and try not to lose too much in mileage...right now I get during the warm weather about 31-33 miles on electric. Winter about 28. What would everyone suggest? I am looking at the Yokohama Avid Ascend GT All Season. Has anyone have any experience with Firestone Weathergrip? Or is there something better? I would appreciate any ideas...thanks.
  2. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
  3. Trollbait
    12,799
    My Outback came with Avids. Can't say if they are the exact same model you listed here, nor give a detailed review, as I have only had the car for maybe two months, though no complaints. I have considered Avids as replacement tires for other cars in the past. Usually ended up with some type of Hankook Kinergy because of price. I did have the ABS activate on dry pavement with them on the Sonic, and they were OEM to the car, but then I run tire pressures higher. Otherwise no complaints on wet roads. Issues in snow had more to do with the car's traction control.
  4. Mendel Leisk
    42,231
    Maybe Michelin Defender T+H?
    Merkey likes this.
  5. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    I have a 2017 and put on Michelin Defender all season tires. Been very happy with them.
    TGrracie and Merkey like this.
  6. Hydrocket
    Hydrocket Member
    79
    39
    CA
    Technology
    I put some Michelin CrossClimate tires on mine.
    It's an "all weather" tire..essentially an all season tire that's rated for snow...has the mountain snowflake symbol on it.
    Not as good as a dedicated winter tire, but better than a traditional all season.
    Pretty pleased with them. Have used them for 2 winters and have nearly 50k KM on them
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    @jerrymildred is using Yoko Avid Ascend (not sure if it is GT or other iterations of Avid) and he is very happy with the results he has been getting on his PP. I have not used Yoko on my PP, but had an older Avid Ascend model BlueEarth LRR tire on my HCH and was very happy with it. Yokohama makes Avid Ascend in both GT and LX. According to the Yokohama website, both GT and LX have similar characteristics. I believe in general LX is less expensive. I once was about to buy LX for my 2017 PP, but it was cheaper to trade it in for a 2020 PP, so I did not buy new tires for it. So far, I have only had OEM tires on all three PPs. Find Your Yokohama Tires | Yokohama Tire
    jerrymildred likes this.
  8. shebobg
    46
    Did you lose a lot of electric miles with them? I know I'll lose some but don't want to take a big hit.
  9. shebobg
    46
    Did you lose a lot of electric miles with them? I know I'll lose some but don't want to take a big hit either.
  10. shebobg
    46
    Do you lose a lot of electric miles with the Defenders...I heard that they take a big hit and even though I know that I will lose some miles when the tire is new, I don't want to lose a lot.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Mine are the GTs. I put them on at 24,803 miles. Car is now at 63,999. Tread depth varies from 6/32 to 7/32 (started new at 12/32). We drove in the rain last night and it still has great wet grip. They are at least as quiet as the original tires.
    Salamander_King likes this.
  12. prius16
    462
    246
    New England
    2022 Prius Prime
    You're in Southern NJ.
    Imho, below I-195 in NJ, there are likely "fewer winter snow storm travel impacts".
    Still, if someone has to go to work, or go somewhere when there is a snow storm, I recommend that they use Blizzak snow tires for the possible snow season.
    You also mentioned that travel during snow storms is not a major concern.
    Imho, that's important. :)
    Therefore, I suggest getting the same tires that are the OEM tires on many Rav4 Hybrids.
    The Michelin Primacy A/S.
    It seems like these are Michelin's replacement for their previous offered Energy Saver tires. Their previous Energy Saver tires where often at/near the top is gas mileage performance.
    Buy Michelin Primacy All Season Tires | Michelin
    Developed to meet the demanding standards of top vehicle manufacturers, the MICHELIN® Primacy™ All Season tire is the latest generation of fuel-efficient, all-season performance. Chosen by Premium Carmakers
    Low Rolling Resistance
    Quiet & Comfortable Ride
    Mileage warranty: 55,000 miles.
    The latest generation of fuel-efficient, all-season tires.
    Next-generation compounds break the grip vs. rolling resistance compromise. Proprietary synthetic rubber compounds designed and manufactured exclusively by Michelin efficiently adhere to dry, wet and snowy roads.
    A quiet ride all year long.
    Symmetric tread design tuned with Piano Acoustic Tuning minimizes noise generated by the tire. Full-depth grooves and sipes do not wear away to disperse water and grip the road through the full life of the tire.
    Developed to exceed the demanding standards of top OE manufacturers.
    Chosen by Ford, Toyota, Nissan, Hyundai and GM as original equipment.
    At Tire Rack:
    (Tire Rack has many affiliated tire shops all around the country. They can ship the tires to that location, or to your local garage/mechanic. I have Tire Rack ship to a local garage, I notify the garage first and get the okay. After the tires arrive, I'll drop off the car, or bring them 2 tires at a time. I've been doing that for decades. :))
    https://www.tirerack.com/tires/tires.jsp?message=singleSize&tireMake=Michelin&tireModel=Primacy+A%2FS&partnum=965TR5PAS
    There are trade-offs for tires.
    The Michelin Primacy A/S tires are good in smaller snow storms, and semi-slick (semi-icy) roads. And, get great Hybrid/PHV/EV gas mileage.
    The Michelin Defender tires would better in adverse weather conditions. However, with a slight MPG/ev-range reduction.
    For ice, heavy snow, or the !Zombie Apocalypse! :eek:, I'll take my Blizzak snow tires over even the Nokian winter tires. (y)
    For a sports car, for ultimate performance in a "street-able" Summer-Only tire, I still like Bridgestone's Potenza series tires:
    Bridgestone Potenza S-02 ; Max Performance Summer UTQG: 140 (those tires last only ~10K miles).
    If specific characteristics are more important, as expected, there are trade-offs in tire selection. :)
    Good Luck!
    #12 prius16, May 22, 2022
  13. prius16
    462
    246
    New England
    2022 Prius Prime
    POS server doing multiple posts.
  14. prius16
    462
    246
    New England
    2022 Prius Prime
  15. prius16
    462
    246
    New England
    2022 Prius Prime
  16. prius16
    462
    246
    New England
    2022 Prius Prime
  17. prius16
    462
    246
    New England
    2022 Prius Prime
  18. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I'm in NJ too. I use Nokian WR G4 tires. After initial break in and warmer months, I'm getting what I used to get on my stock Dunlop Enasave tires (Non-prime). It's an all weather, LRR tire and it's been great. Installed in November 2021 and I've already put 12k miles on them and they still look new. The ride is super comfortable even at 42/41 psi. Even on coilovers. I was looking at the Michelin CrossClimates but I didn't see any mention of low rolling resistance so went with the Nokians. IMG_20211106_080941.jpeg IMG_20211106_133947.jpeg IMG_20211106_133926.jpeg
  19. Mendel Leisk
    42,231
    Not sure if Michelin Primacy A/S are the same as Primacy MXM4, but I got the latter in 215/45R17, and coming from OEM Pilot HX MXM4, my mpg TANKED. Slowly coming back, but I don’t see them being anywhere near Energy Saver A/S. You have to take rolling resistance with a tablespoon or two of salt.
    my fuelly badge used to read 4.9. At 5.0 now, and I can see 5.1 coming. No big deal when you’re doing a half tank every 2~3 months though.
  20. My Nanos ended up near EOL. Dealer quoted 3/32 even though they quoted 5/32 last September. So, I ended up getting GY Assurance Maxlife. These are definitely NOT eco tires, but are pretty close to eco tires at 44 psi.
