2017 Prius Prime Photos
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Sep 22, 2016.
  1. DavidA
    2,349
    1,825
    Chicago western burbs
    Very short sighted on Toyota's part. People carry things back there that could be dangerous or heavy if there's an emergency stop or an accident.
    Case in point... say I place a 2.5 gallon gas can back there so I can get gas for the lawn mower. I need that to not fall over or move at all. Or I want to drive the Al-Can highway. I want to at least have a donut spare with me. What about heavy luggage?.
    I wonder if I drill and install my own D-rings along the side? Anyone know what is involved?
    EDIT: Another double post! This site is a mess!
  2. Trollbait
    12,808
    A few hatchback/wagon/SUV don't have tie downs, or at least ones actually useful. I even like having them in trunks.
    I use the latch points for the seat backs when they are down, and the car seat anchors can be an option. If there isn't any D-rings, and you want to install your own, you'd want to be get behind the plastic where it is being mounted to use a washer back there, or at least a screw with really deep threads. Anything else might just pull out when least wanted.
  3. Trollbait
    12,808
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Yeah, that's a bad move if it's true. I use them from time to time with ratchet straps to hold down things that would otherwise tip over easily.
  5. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I do miss the auto up tailgate that my wife's car has. If your arms are full of bags, just waive your foot under the bumper and the tailgate goes up. Nice feature.
  6. vern748
    vern748 Member
    46
    45
    Sonoma
    DavidA,
    Same situation for me. I need the d-ring. Would love to put one in the same place as the older Prius 2. Did you do the retrofit ?
    gohanvox likes this.
  7. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Not a good idea to carry gas on top of an electric battery.
  8. DavidA
    2,349
    1,825
    No, it sure isn't. Toyota, though, placed a very big battery over a gas tank. :D
    Checking a Prime at a dealer recently confirms there are hidden fold down clips that bungie straps can connect to. They're plastic, but seem pretty firm.
  9. vern748
    vern748 Member
    46
    45
    Sonoma
    I use my Prime for work and needed a way to secure a ladder in the back. Since Toyota decided to not bless us with a tie-down or d-ring, I needed to add one myself.
    At the very rear there is small mushroom likely to hold a bungee cord. If you pull out the mushroom, you will see a screw. Take out that screw. Take out the screw insert if you need something stronger. The plastic screw insert can only hold so much weight. You will need to pull out come of the panel clips to allow access to the back of this screw area. Using a 5/16 threaded stock with a bolt and washer, pass it through the hole from the back. (The hole is just at 5/16.) Your threaded rod can't be too long or you will never get it threaded through the plastic opening the original bolt came from where it passes through the interior plastic. Tighten it down with a lock washer and bolt from the exterior side.
    Cut threaded rod to size.
    On the end I used an eye nut to be my attachment point.
    Cheers
    Vern
    #149 vern748, Mar 5, 2017
  10. vern748
    vern748 Member
    46
    45
    Sonoma
    Error Eye Nut and not eye bolt. OOps
    #150 vern748, Mar 5, 2017
  11. DavidA
    2,349
    1,825
    Photos of this would help bigly.
  12. vern748
    vern748 Member
    46
    45
    Sonoma
    Photo is attached to the original post. Photo is looking inside the hatch to the right rear of the vehicle. Gray sky to the top. Ladder rungs are vertical in the car. Photo is just below the height of the new attachment point.
    Vern
    #152 vern748, Mar 7, 2017
  13. DavidA
    2,349
    1,825
    Ahhh. Didn't see that for some reason. Thanks.
  14. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
  15. huskers
    2,548
    2,488
    Nebraska
    Wow, that is amazing.
  16. MNdriver
    MNdriver Senior Member
    549
    577
    Huskers is back! How was Disneyworld?
  17. huskers
    2,548
    2,488
    Nebraska
    Amazing. They spend 60 million on fireworks a year. Crazy. Walked over 18,000 steps a day for 7 days. Car stayed at in my brother's garage all safe and sound. Good mileage that way. Trip was fun but those rides can take it our of you. Glad to be back home and seeing who got their cars since I was gone.
    Oh, and I looked every day to see a Prime in the wild. They were a no show.
    #157 huskers, May 28, 2017
    bisco and MNdriver like this.
  18. john1701a
    12,840
    5,312
    58
    Delivery of my wife's Prime is expected within the next few days. Then, we'll have a red one to add to the photos. :cool:
    huskers likes this.
  19. huskers
    2,548
    2,488
    Nebraska
    His and Hers Primes. Sounds like a love story in the making.
  20. JBW
    JBW Junior Member
    Anybody have pictures with the body side moldings? My exterior color choice is blue magnetism but pictures of any exterior color should help me decide if I want these.
