2017 Prius Prime (Plug-in Hybrid) Full Product Information & Technical Docs (PDF)
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Oct 3, 2016.
  1. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    It saves all your customizable memory settings - radio stations, time, etc. It may defeat your reset purpose, I'm not sure how that is set up.
  2. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Sounds good to me.
    But I'd like to clarify - was your Prime parked in your garage and plugged in to charge and you left in EV mode and got heat from the heat pump withn 200 feet of leaving the garage and the engine never started on your entire drive?
    If yes how far did you drive in EV mode without the engine starting?
    Was the car parked in the cold outside without charging, how long, and were you able to use EV to get home without the engine starting?
    Thank you
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Just looked at site, this is another subject. The only memories lost when battery is disconnected is the clock and date. This was true in my 2005 and 2012. Both are easy enough to reset. If one wants to spend $12.00 to not have to reset clock and date, go to it. It may even interfere with the original plan of returning close to original new car range.
    My prime is parked in the garage and L2 charger is also in garage. There seems to be no limits on EV mode. It seems I can drive forever in EV mode, right now range is 29 miles. Being a veteran of 4 Prii now I don't tempt fate, I keep the acceleration light and never turn the heat up high. Most of my eco scores are 3/4. Most of our temps are modest, snow in Cool but not in Sacto.Yes, I too was amazed that warm air flowed shortly after exiting my garage. Hope that answers your questions. Andy
    To change the subject. I am also selling my 2013 Prius C. Listed on Craig's list for Sacramento Has under 13000 miles on it and CLEAN.
    That's the negative, not enough space but I'm traveling around with the back seat down, then there is more than enough space.
    #223 Andyprius1, Jan 3, 2017
    51,968
    thanks, that's what i was afraid of.:unsure:
  5. Andyprius1
    2,327
    859
    Cool CA
    Just improvise.
  6. bisco
    51,968
    it may come to that, we'll see after i test drive a bolt and ironique.
  7. Andyprius1
    2,327
    859
    Cool CA
    Ironnique..............
    .Wazat?
    priuscatprimeguy likes this.
  8. bisco
    51,968
    some crazy corean plug in, supposedly coming, but who knows?
  9. Andyprius1
    2,327
    859
    Cool CA
    North or South Corey.?
  10. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  11. bisco
    51,968
    it's a hondai.
  12. Andyprius1
    2,327
    859
    Cool CA
    Exactly my preference.
  13. priuscatprimeguy
    2,730
    2,640
  14. Andyprius1
    2,327
    859
    Cool CA
    Guy on coast to coast hinted everything is neither there or not depending on ones mindset, A factual scientific
    Evaluation agreed upon by many in the Scientific World. He calls it Synchronicity. And Spooky.
    His name is Dr. Kirby Surprise.
    #234 Andyprius1, Jan 3, 2017
  15. Trollbait
    12,543
    Didn't one of them die a few years ago?
    priuscatprimeguy and bisco like this.
  16. Andyprius1
    2,327
    859
    Cool CA
    Agree there will be some resets, clock, Apps maybe.
    Actually, I think it would, the object IS TO REBOOT, If a spare battery is connected thru the OBD 2 port before disconnecting 12 V, that would be the same as NOT disconnecting, hence no reboot.
    Iincidently there is one on EBay for $6.99. I would only reboot IF I had triangle or code warnings. Good procedure before running to dealer.
    #236 Andyprius1, Mar 24, 2017
  17. bisco
    51,968
    really? you aren't rebooting like the pip anymore?
    giora likes this.
  18. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    If you set that to 8 Amp it will affect 16A 240V also
    84 MPH
    112 Hybrid
    #238 Samprocat, Mar 24, 2017
  19. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That's for Ev mode. The question was about Hv mode.
  20. Samprocat
    491
    297
    Lincoln, NE
    Anything over 35 Mph affect drag...so more power is required...1/100 seems nothing to ordinary user...where to the Engineering is fighting with design vs drag efficiency
    190 Km/h tested on my vacation in Europe Premium Prius Prime
    #240 Samprocat, Mar 24, 2017
