2017 Prius Prime (Plug-in Hybrid) Full Product Information & Technical Docs (PDF)
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Oct 3, 2016.
  1. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    To me they look more like predator jaws. I wonder if I could get those as a custom paint job for cheap...
  2. Trollbait
    12,539
    To better appeal to more buyers, form is starting to not follow function.
    Mendel Leisk and Felt like this.
  3. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    i'm not sure if it appeals. Prius 2017 has been some of the most fugly lines i've seen. Still interested in the car.. but man do they make the decision hard.
    Felt and bisco like this.
    51,933
    yep, those jowls are something, no way to know if more people will be interested in them, or, not.
  5. DavidA
    2,345
    1,821
    Chicago western burbs
    The thing is, above the front badge, it is a great looking design, as I see it. But below the badge, it is a complete hideous mess.
    Prius Maximus, Felt and bisco like this.
  6. Tideland Prius
    16,557
    The others have mentioned it. The Prime's front end design was focused more on style than aerodynamics. They tried to offset it with the dual-wave rear glass.
    Because it's only to two significant figures, it could be a difference between 0.244 and 0.245 and rounding would make them 0.24 and 0.25. Of course it could be as large as 0.235 and 0.254.
  7. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    .01 difference in the drag coefficient could not possibly make any difference except at very high speeds. How about some of you engineers working out what that speed would be. Here in the mountain west the Interstate speed is often 80 mph. I'm imagining that .01 drag differential would be barely noticeable in a tank of gas if you drove 80 mph the entire trip (which you never would).
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    50 m/sec=180 km/hr=~112 mph
  10. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Lee Jay, is the difference line using a different scale, e.g. x10?
  11. Nougatti
    Nougatti Member
    119
    59
    Norway
    The Prime BETTER make sure to use the FRICTION BRAKES when the battery is completely full at the top of a hill.
    The PiP engages the gasoline engine for braking when this is the case, and doesn't turn it off at the bottom of the hill either, because warmup. Warmup is apparently very important.
  12. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    To use up the excess electricity, the system spins the engine. No gas is consumed in that process.
    With an aftermarket gauge, you can see the RPM going up & down. The engine never actually starts.
    Robert Holt likes this.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The difference line is read by the second 'y' axis (on the right).
    On second look the units on the 'y' axis (Wh/m) do not look right for the numbers shown, maybe should be Wh/km? Wh/mile?
    #53 giora, Oct 14, 2016
  14. bisco
    51,933
    the thing is, toyota usually strives to make incremental improvements, many of which seem negligible to the consumer.
    here, they've taken a small step backward, for a questionable design cue. there had to be some major rumbling going on behind the scenes.
    Felt likes this.
  15. john1701a
    12,818
    5,303
    58
    Drawing that conclusion requires assumption of goals.
    What do you think they are for year 1 ?
    Think about how the Classic model was rolled out...
  16. bisco
    51,933
    sales goals?
  17. Lee Jay
    5,850
    4,036
    Yes...watt hours per mile. I'd like to blame my stupid mile abbreviation on the fact that I got out of bed and went downstairs to quickly produce that plot.
  18. Nougatti
    Nougatti Member
    119
    59
    Norway
    Yeah, except in a PiP, when the engine is engaged, even for the gas-less spinning to engine brake, it doesn't die and reengage pure EV mode again as soon as the downhill portion is over.
    Only after a complete warm-up cycle or if I stop the car, turn the power off and start it again will it reengage pure EV mode.
    The same happens if I inadvertantly turn the heater on or set the AC to higher than the ambient temperature.
    Even if I turn the heater right back off again, the car will continue to operate the gas engine until it's reached sufficient warm-up temperature.
  19. bisco
    51,933
    correct, but prime has pure ev mode, pip does not.
  20. Nougatti
    Nougatti Member
    119
    59
    Norway
    It's not just a normal Prius with a larger battery pack. It's much stronger in EV mode than a standard Prius. The PiP does have pure EV mode for some 20 km, apart from certain circumstances where much power is needed or heater is on, etc. I can't see where it says the Prime does otherwise in those special circumstances.
