2017 Prius Prime (Plug-in Hybrid) Full Product Information & Technical Docs (PDF)
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Oct 3, 2016.
  1. bisco
    51,944
    thanks, i was afraid of that. one of the best features toyota ever came up with imo, i use it all the time. amazing at keeping fumes, smells and dust out of the cabin.
  2. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    You mean the filtration cycle? That's gone? So when I'm stuck behind one of those nasty "clean diesels" spewing smoke and causing cancer I can't filter the cabin air? very disappointing. I use that all the time, like just about every day.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    What's wrong with just turning it on recirc?
    51,944
    completely different. recirc is about 80%, filtration is 100%. you na go through a dust storm, or behind a coal roller, and nothing comes in the cabin. it's a fabulous feature.
  5. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    What top speed do US Prime models have in HV-Mode ?
    It seems it's gone down in Europe from 112 to just 100 mph according to Netherlands specifications .
    #125 civicdriver06, Nov 3, 2016
  6. Tideland Prius
    16,559
    The air is always going through the filter (why it's labelled as "dust & poller filter mode" in the manual is beyond comprehension as it makes it sound like the air isn't filtered unless you press that button).
    All that button does is close the outside vent 100% (normally, recirc is 80%). Recirc does the same job but will take longer because of that 20% opening in the vent position.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    EU manual does say (in remarks area) that dust will be collected on the filter even when the temporary pollen mode is not used.
  8. bisco
    51,944
    yes, that's correct. but you will get smoke, fumes and smells right through the filter into your nose and lungs. that's why 100% recirc is better in some situations. i always use it behind large diesel vehicles and when passing through dusty construction sites, or things like roadside fires.
    MERGED USE MULTI QUOTE
    can you clarify the last sentence? i don't see how 20% outside air can be doing the same job.
    #128 bisco, Nov 3, 2016
    Prius Maximus likes this.
  9. Tideland Prius
    16,559
    80% of the airflow is recirculated air so you're constantly filtering out the air inside the cabin whilst only adding 20% outside air. I didn't say it's doing the same job exactly. I said it'll just take longer because there's still outside foul air thats being mixed in in recirc mode. Apparently 80/20 is enough to dilute the air such that he odour is gone.
    Insirt and bisco like this.
  10. bisco
    51,944
    thanks, i get it. so eventually, that horrible diesel exhaust i'm breathing will leave the cabin. sometime after the vehicle is no longer in front of me.:cool:
  11. ttait
    ttait Active Member
    273
    163
    Southern California
    I'll probably miss that ionizer when I have to drive through Stockton. Cows for miles.
  12. Prius Maximus
    956
    811
    Northeastern IL
    So Toyota is telling us that speeding to get in front of the coal roller is acceptable, or even recommended. Then we have to roll down all the windows to get "fresh" air which is still pollen- and pollution-laden. Nice.
    Or is this Toyota's way of fixing the mouse house in the air filter: Don't let 'em filter the air, they'll have to open the windows, and won't notice the mouse smell.
  13. bisco
    51,944
    unfortunately, they're the masterminds of decontenting. the least they could have done is put it on the premium package.
  14. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    I think your simple answer is right. The why perhaps is in emission regulations that assume that when the ice starts, it soon will be powering the car. And this is usually the case. I suppose it is also possible that the ice must be gas powered to use up the extra electricity produced while regenerating with a full battery. I have never read a full explanation of what goes on in that scenario.
    I asked Danny if the Prime would turn the ice on when regenerating with a full battery. He replied he thought it would but did't know, and would ask an engineer. I never heard anything more.
    #134 CraigCSJ, Nov 4, 2016
  15. Lee Jay
    5,850
    4,036
    Pumping losses. If you spin the engine you'll lose energy pumping air through the engine from intake to exhaust because that process is not 100% efficient. The faster you spin the engine, the more the losses. Adding gasoline and igniting it produces power thus reducing the loss so you don't want to do that if you don't have to when you're trying to absorb energy. Just spin the engine.
    Does anyone have information on the 12V subsystem? My 2004 was rated at a sustained 100A but I can't find the rating of the 12V power supply in either the Prime or the Gen 4 anywhere. This matters if I have to run my house off of the 12V system through inverters in an emergency.
    Tideland Prius likes this.
  16. bisco
    51,944
    you get a bigger 12v battery, does that help?
  17. Lee Jay
    5,850
    4,036
    No, it does not. The actual energy stored in a 12V car battery is quite low - around 300-500Wh at high demand. I have a 2000W inverter and a 300W inverter that can together kill a car battery in 10-20 minutes. In a long-range power outage, people have run inverters off their Prius for days.
  18. bisco
    51,944
    with the car in ready.
  19. Lee Jay
    5,850
    4,036
  20. Trollbait
    12,542
    Have you had issues using the inverters with the gen2? With the car on, the battery shouldn't be the weak link. I also doubt Toyota dropped the amperage of the 12-volt system since 2004; cars have more stuff to power today.
    @bwilson4web recommends hardwiring the inverter to the car if you are using them to power a whole house.
