2017 Prius Prime (Plug-in Hybrid) Full Product Information & Technical Docs (PDF)
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Oct 3, 2016.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    No, but I constrain myself to its capacity. That's why I want to know the capacity.
  2. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Thanks for the tech documents Danny
    I gather that the Prime comes with a charging cable fitted to the Prime on one end and a US 110v outlet on the other.
    How is a 240v/20A (16A continuous) outlet accommodated, since the expected plug is different ?
  3. Lee Jay
    5,850
    4,036
    You'd have to buy a 240V charging cable or charger (or have the standard one modified - not just the plug) to accommodate 240V charging.
  4. EV-ish
    602
    278
    SW US
    I think I am following ...
    A 240v EVSE that plugs into the Prime. What port(s) does the Prime have ? Chademo ? SAE J1772 ?
  5. Lee Jay
    5,850
    4,036
    The Prime has the standard L2 J1772 port in the US. It has space for a Chademo port in other regions.
    EV-ish likes this.
  6. EV-ish
    602
    278
    SW US
    The document in the OP says that the car can be set to standard draw of 8A or 'max'
    What is the max amp draw ?
    Does it vary by voltage ?
    Am I correct in thinking that the owner is given a choice to pull up to max rating of the EVSE to the limit of the car ?
    I'm now wondering if I should just upgrade a breaker on a 110v circuit to 20A if the wiring to a convenient isolated outlet will support a 16A continuous draw. That would be good for about a 1.7 kW AC stream to the car, so perhaps 1.4-1.5 kW DC to the battery and a 3.5 hour charge time ... I think.
    Thanks for the help!
    #146 EV-ish, Nov 17, 2016
  7. Lee Jay
    5,850
    4,036
    It draws 12A at 120V and 16A at 240V. The 8A programmable limit applies to the 120V source for sure, I'm not sure if it applies to the 240V source or not.
  8. EV-ish
    602
    278
    SW US
    I'd like to be sure I understand your answer:
    120v:
    Max draw of 12A
    Has an 8A setting in the car (as default ?)
    240v
    Max draw of 16A
    May have an 8A setting (as default ?)
    Sorry for being dense about this, I'm a (hopefully) careful newbie
    MERGED
    The Prime has a max 3.3 kW draw rate.
    Is this 3.3 kW AC before the AC/DC converter or 3.3 kW DC after the converter ?
    I wondered after realizing that 240v * 16A = 3.84 kW AC
    #148 EV-ish, Nov 17, 2016
  9. Lee Jay
    5,850
    4,036
    8A is the alternate, not the default.
    3.3kW is the charger output, not input.
    EV-ish likes this.
  10. Trollbait
    12,542
    The ultimate limit for SC charging is the charger installed in the car.
    The EVSE(the charge cable) that comes with the car is limited to 12A. To get faster charging from a 20A outlet, you'll need a EVSE that can handle the higher amperage.
    If the line is only 15A now, I'd look into going to 30 or 40 amps instead of 20A. The Prime won't charge faster, but you'll be set if a BEV is a future consideration.
    Tideland Prius likes this.
  11. EV-ish
    602
    278
    SW US
    I'm confused about pre-heating, since it seems to vary by trim
    I expect to buy the base 'plus' but have not completely excluded the advanced (for the 3 door SKS.)
    Is cabin pre-heating and/or battery pre-heating available using the home charger rather than the battery charge ?
    #151 EV-ish, Nov 18, 2016
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This statement is only true if you charge with the Toyota supplied portable EVSE ("cable"). Using third party's portable L1 EVSE with a current limit of more than 12A you will charge the prime faster. The car charger is not limited to 12A on L1, it is a 3.3kW charger.
    See as an example this
  13. Lee Jay
    5,850
    4,036
    It's always from the battery. However, if you are on charge at the same time the charger can make up some of that draw (L1) or all of it (L2) while the heating is in progress.
    EV-ish likes this.
  14. bisco
    51,944
    what is the charge limit for prime?
  15. EV-ish
    602
    278
    SW US
    Excellent -- thanks very much for the replies.
    Sounds like another good reason to place an L2 charger at home. If only the car was smart enough to roll up my windows before pre-chill in the summer :)
  16. Trollbait
    12,542
    A 16amp EVSE still won't let a Prime charge faster off of a 30, 40, or even 50 amp outlet, which is what you quoted was referring too.
    L1 is limited to 120V, and that EVSE can draw over that amount. Offering an adapter so that a 16amp appliance can be plugged into a 15amp outlet is setting the seller up for a lawsuit.
    It was mentioned here or in another thread the level 2 specs was 16A/240V. That requires a 20amp circuit EVSE. You want the draw of the appliance to be lower amperage than the outlet rating. The circuit breaker should trip when the outlet rating is reached.
  17. bisco
    51,944
    thanks, and what's the max amp at 120v?
    EV-ish likes this.
  18. Lee Jay
    5,850
    4,036
    It's not specified. However, the logical possibilities are 12A (the default) and 16A (the 240V current draw). I find the likelihood that it's power-limited (i.e. that it could charge at 3.3kW at 120V if current were available) to be low.
  19. bisco
    51,944
    that's why i'm interested in @giora 's expertise.
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    What I said is that 16A EVSE will let the Prime charge faster than the stock 12A one.
    As for the adapter thing, you completely misunderstood the seller statement, it is not an adapter to the 15A outlet but to the EVSE side to mate a 20A outlet.
