2017 Prius two Side mirror glass replacement
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by pilotlife, Dec 11, 2017.
  1. pilotlife
    pilotlife New Member
    I had bought cheap adjustable blind spot mirrors, although they broke. So I was working on getting them off and I had managed to crack the glass on both side mirrors. The one on the right only has a small crack in the corner and it's covered by the new blind spot mirror, so I'm not as worried about that. But the left one has many large cracks and it's disorienting. Both mirrors are heated. Does anyone know if I need to replace the whole assembly, or just the mirror glass, or what. Does anyone have part numbers?
  2. Adam1a
    Adam1a Member
    50
    59
    Three Touring
    If I’m reading it right, you can get the mirror glass separate.
    87961 MIRROR OUTER, LH
    87961-47400
    87961-47410 BLIND SPOT MONITOR-WITH & WITH(REAR CROSS TRAFFIC ALERT)
    87931 OUTER MIRROR, RH
    87931-47410
    87931-47420 BLIND SPOT MONITOR-WITH & WITH(REAR CROSS TRAFFIC ALERT)
  3. Dxta
    Dxta Senior Member
    1,943
    769
    Lagos
    You can perfectly repalxe the mirrors separately, if you're comfortable doing em.
    The key is, you've got to be careful when detaching the mirrors from the clip that holds it to the mirror plastic assy. If that would pose a problem to you, get it replaced by town town shops. Might be cheaper.
    Dxta
