2017 Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Steve Kind, Aug 18, 2023.
  1. Steve Kind
    Steve Kind Junior Member
    2017 Prius v wagon
    Woke up this morning and this is what I saw on the dash Any idea what could be wrong
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Does the car go into READY? How old is your 12V AUX battery?
    Doug McC likes this.
    52,849
    could be a speed sensor, bad tires, wheel bearing, brake actuator. get the trouble codes read by someone with hybrid aware scanner.
    you can try auto zone for a free scan, sometimes it helps, sometimes it doesn't.
    Brian1954 likes this.
  4. Steve Kind
    2017 Prius v wagon
    12 volt battery is only 2 months old
  5. Steve Kind
    2017 Prius v wagon
    I have an A
    I have an Ancel AD310 scanner and it came up with no problems
  6. Steve Kind
    2017 Prius v wagon
    Went to Auto Zone and this is the scan
  7. Air_Boss
    4,259
    1,197
    New Yawk
    That would be really quick for a brake booster/accumulator/cylinder failure. No codes? Interesting.
  8. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    I see a Code appear as 1391 (on the report above).
    One Internet search shows:
    What are the Possible Causes of the DTC C1391 Toyota? NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes. Fluid Leakage Faulty Brake Actuator Assembly Brake Actuator Assembly harness is open or shorted Brake Actuator Assembly circuit poor electrical connection
    Check here How to Fix the DTC C1391 Toyota? Review the 'Possible Causes' mentioned above and visually examine the corresponding wiring harness and connectors. Ensure to check for any damaged components and inspect the connector pins for signs of being broken, bent, pushed out, or corroded.
    Need More Information on the C1391 Toyota Code? Get Access to Factory Service Manuals
    Read more: https://www.autocodes.com/c1391_toyota.html
    FWIW. You did not accidentally press the traction control button driver's left lower button panel; did you?
    Mice. Known issues.
    Good luck.
    Air_Boss likes this.
  9. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Bummer......... $1500
  10. Steve Kind
    2017 Prius v wagon
    I might have accidentally pressed the traction control button. How to I reverse that? I’ve tried to press it again but nothing happens
  11. rjparker
    rjparker Tu Humilde Sirviente
    11,098
    6,964
    Texas Hill Country
    This was a problem acknowledged by Toyota through the 2015 v. The 2017 is still a gen3 so you might try the dealer.
    Tim Jones likes this.
  12. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Have you noticed the brake pump running more often. It makes the noise when you open the door in the morning.... you should rarely hear it.
    One symptom is that it runs often.
