2017 Toyota Prius error code
Discussion in 'Gen 4 Prius Technical Discussion' started by Crazycajun, Jul 16, 2018.
  1. Crazycajun
    Crazycajun New Member
    Louisiana
    Does anyone know what could cause the codes below? Car is being rebuilt from minor front and rear damage.
    ----Antilock Brake System Codes Scan Report----
    2 Antilock Brake System Trouble Codes:
    1. C1417
    IG1 Voltage Supply too High
    2. C1425
    Open in Stop Switch Circuit
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Just a WAG ...
    If the circuit is open (no load) then voltage would likely be high.
    Perhaps a connector needs reattaching?
    J
    Crazycajun likes this.
    52,863
    welcome!
    who is rebuilding it?
  4. Crazycajun
    Louisiana
    I am 1st time. I have most of the front and rear off right now. I just wasn't sure what could be disconnected with the AntiLock system.
  5. bisco
    52,863
    you might need to subscribe to tech info.toyota.com for the service manual and troubleshooting tree.
  6. Crazycajun
    Louisiana
    Yes I will if I have too. Just wanted to see if anyone had any info on this or things to look at before I spent the money just for this one item.
  7. bisco
    52,863
    all the best!(y)
  8. Crazycajun
    Louisiana
    does "info Toyota com" also have instructions on how to dismantle the Prius inside and out?
  9. padroo
    padroo Senior Member
    2,763
    2,253
    Start with the 6 fuses for ABS in the engine fuse box, four are 30 Amp and two are 10 amp.
    I have access to wiring diagrams for my 2016 I got from a subscription to Do it Yourself Automobile Repair Manuals - Mitchell 1 DIY
    There are three pages to the ABS System.
    They are owned by Snap-On Tool.
    There are six more fuses under the dash fuse box.
    I am assuming your year newer car is the same as mine.
  10. Crazycajun
    Louisiana
    Does it have dismantling instructions for external and internal parts?
  11. Elektroingenieur
    2,515
    3,288
    Three Touring
    The website is techinfo.toyota.com, and a subscription ($20 for two days) includes access to the Repair Manual, which has instructions for removing and installing most of the parts of the car, along with troubleshooting procedures for all the diagnostic trouble codes, including C1417 and C1425.
    Toyota also publishes a Hybrid Vehicle Dismantling Manual (PDF), available at no charge from the same site, as a guide for safe disposal of the car at the end of its life.
  12. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not to nitpick but it is only $15 for two days.
    J
  13. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Elektroingenieur likes this.
  14. bisco
    52,863
    that is a 33% increase.:mad:
  15. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
  16. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Still worth it though ;).
    Hard to get direct information at that price:).
    When you buy it for 2 days, be ready to download and save as much as you can(y).
  17. Njner
    Njner Junior Member
    2018 Prius Prime
    Are all the documents in the library downloadable with the subscription?
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’ve only ever delved into the repair manual and wiring diagrams ;).
    But with the subscription, they work well(y).
  19. Elektroingenieur
    2,515
    3,288
    Three Touring
    Not conveniently, but I think there is enough to justify spending $20.
    The service bulletins and campaign publications are PDF documents, as are the technical training course books, though each chapter is a separate document, just over 350 in all.
    For recent models, the Repair Manual, New Car Features, and Collision Repair Manual books are presented not in PDF, but instead as thousands of HTML documents, one per topic. You can print topics individually to paper, or to PDF, if you’re using Google Chrome or another browser that supports this.
    I wrote about the Electrical Wiring Diagram viewer in a previous thread.
    alanclarkeau likes this.
