2017 v 105,000 miles, how much should spark plugs service cost?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Agusto2017, Sep 5, 2021.
Tags:
  1. Agusto2017
    Agusto2017 Junior Member
    42
    Waterville, Ohio
    2017 Prius v wagon
    Hi. I took my babe to the Toyota dealer and had her coolant service and transmission service done. Next month I’ll get her spark plugs. The dealer said it would cost around $400. Is that a fair price? I’ve always had the dealership do her maintenance but this one sounds quite pricy. Is it?
  2. ttou68
    ttou68 Active Member
    351
    209
    Depending on how much and how long they are charging you in labor, spark plugs should cost you around $40 and rest will be labor to take off and put back all the parts in the engine bay to get to the spark plugs..
    Normally it took me no more than an hour to change out the spark plugs...
    Agusto2017 likes this.
  3. xliderider
    xliderider Senior Member
    8,049
    3,218
    Honolulu, HI
    I just did my own spark plugs at 124k,using Nutz About Boltz's video(s) on this website. Cost me twenty something for Bosch Double Iridium plugs and a fair bit of elbow grease and perspiration. It is definitely doable if you know your way around some tools.
    The only other things that I had to buy was a new spark plug socket, some copper anti-seize compound, and some dielectric grease.
    All in, less than $50. More, if you add in the requisite number of beers consumed (to replenish fluids lost through perspiration).
    51,098
    yeah, that's pretty pricey. i'd say $200 is fair, $250. at a dealership
  5. Agusto2017
    42
    Waterville, Ohio
    2017 Prius v wagon
    Thanks folks!
  6. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    Looked up a spreadsheet I have on cars I have owned.
    Last Toyota spark plugs replaced at dealership cost $157 for a Toyota Corrolla. irridium sparkplugs.
    That's in Canadian Dollars so about 157 Canadian so about $125 US.
    $400 is a ripoff.
  7. Mendel Leisk
    40,548
    This might be helpful:
    Search string:
    DENSO SC20HR11
  8. gromittoo
    gromittoo Active Member
    719
    287
    philadelphia
    2013 Prius v wagon
    The Prius requires removing the windshield wiper assembly to get to the spark plugs. This is a PITA, and adds a lot of labor cost over a normal car. I don't know Corollas, but a Corolla might be straightforward to remove the plugs. The cost for a plug change in a Corolla might not be a fair comparison.
    Also, buy the plugs from the dealer. The dealer plugs don't cost that much more than aftermarket (~$40 for 4 plugs). My dealer has them on sale for $8.88 each:
    https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-2008-2020-toyota-spark-plug-9091901275
    Given how hard the plugs are to replace, why take a chance with aftermarket? Get a local shop with lower labor rates to install them.
