2018 ABS, Headlight System and pre-collision message on
Discussion in 'Prius c Main Forum' started by steveinflorida, Feb 29, 2024.
  1. steveinflorida
    steveinflorida New Member
    2018 Prius c
    2018 Prius C one, 156000 miles, car runs-drives and stops fine and all lights working.
    I have and ABS (red warning light) and a headlight system and pre-collision system malfunction message on the screen. All three apperaed at the same time. I went to the dealer and paid $230 for a diagnostic service and the asked if I have had the right wheel bearing assembly replaced. I had replaced it about 4 months ago without anyproblem since. It was a cheap $40 replacement assembly from Amazon..... so I assume that the sensor had crapped out.So much for saving money..... Dealer wanted $700+ to replace it needless to say I opted to buy beeter quality one and do it myself...I retired I got an hour to kill. Still have the lights on, Do I have to have Toyota reset the malfunction lights? Is there any way that I can do it?
    52,862
    have you tried disconnecting the 12v negative?
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Next time get an OBD2 scanner and do not buy cheap parts. And Jesus paying $230 to get the car scanned, that's a scam man, do not let that happen again. Do not pay the dealer ''stealer'' to replace that, that's ridiculous they are ripping you off.
