2018 Camry Hybrid MPG Table
Discussion in 'Toyota Hybrids and EVs' started by Tideland Prius, Aug 22, 2017.
  1. Tideland Prius
    16,681
    Specification LE Hybrid (Can) LE Hybrid (USA) SE Hybrid XLE Hybrid
    1 Curb Weight kg (lbs) 1575 (3472) 1575 (3472) 1610 (3549) 1620 (3571)
    2 Tire Specs 215/55R17 205/65R16 235/45R18 235/45R18
    3 Tire Type Painted Alloy Steel w/ Wheel Covers Painted Alloy Machine-Finished Alloy
    4 Fuel Cons. (L/100km) 4.9/4.8/4.9 4.6/4.4/4.5 5.3/5.0/5.1 5.3/5.0/5.1
    5 Fuel Cons. (US mpg) 48/49/48 51/53/52 44/47/46 44/47/46
    Note the differences between the Canadian and US spec LE Hybrid - one has 16" steel rims and the other has 17" alloys.
    amped, bisco and Spindifferent like this.
  2. Trollbait
    12,831
    Lower cost and a 50+mpg combined for the steelies. Toyota accountants had a party.
    amped and bisco like this.
    52,858
    interesting that they eliminated the 17" wheels in the u.s., i wonder what the thought process was, sportier?
  4. Tideland Prius
    16,681
    Cost and I'm sure they wanted a number over 50 mpg.
  5. bisco
    52,858
    i was thinking more of why they went to 18" on the se/xle from 17".
  6. Trollbait
    12,831
    They likely had already decided upon the 18 inch for the high trims; cheaper to stick with the same wheel sizes in different markets.
    The 17 inch might have been the plan for the US LE, but the price and MPG numbers were seen has better with those 16 inch steelies. Non-alloy wheels on the base might also push some sales up a trim.
  7. bisco
    52,858
    it's funny to think of camry buyers this way, especially hybrid camry. i know toyota has been trying for years to attract a younger demographic, but i'm not sure that youngsters are all that interested.
  8. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    I think younger prospects will be more interested in connectivity than wheels and tires. Toyota's insistence on pushing Entune over Android/Apple may cost them the demo they're desperately trying to attract.
    bisco and Trollbait like this.
  9. amped
    amped Senior Member
    3,892
    694
    You guys also get heated mirrors with signal lamps on the LE, grrr.
    Interesting CA brochure that shows a voltage bump with the LiOn battery, something I haven't seen in the US brochure. HP is the same across the HV board but I'm wondering if the almost 6% higher voltage LiOn somehow improves efficiency besides weight savings or am I overthinking it.
    2018 Camry and Camry Hybrid - Toyota Canada
    Tideland Prius likes this.
  10. Trollbait
    12,831
    Just because the voltage is higher doesn't mean the system can take advantage of it. They could have used a larger a Li-ion pack in the Prius and Camry. We know more capacity can increase efficiency from the plug ins. In addition to the cost of the larger pack, there would have been the cost of programming and validating the control CPU for the larger capacity though. Toyota chose to keep the usable capacity of both chemistries close to save those costs.
    amped likes this.
  11. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Wonder if the flooding in Texas will bring higher gas prices? The oil industry in it's wisdom has chosen a hurricane, tornado and flood plagued area to put the lion's share of it's refining capacity.
  12. frodoz737
    frodoz737 Top Wrench
    4,806
    2,561
    33
    Considering how much oil comes from the Gulf...the wisdom is likely logistics and cost...in the big picture.
  13. bisco
    52,858
    see the recent thread on gas price increases.
