2018 Camry MPG Table
Discussion in 'Other Cars' started by Tideland Prius, Aug 22, 2017.
  1. Tideland Prius
    16,678
    Specification L LE SE XSE XLE XSE V6 XLE V6 LE Hybrid (Can) LE Hybrid (USA) SE Hybrid XLE Hybrid
    1 Curb Weight kg (lbs) 1470 (3241) 1495 (3296) 1515 (3340) 1540 (3395) 1520 (3351) 1620 (3571) 1610 (3549) 1575 (3472) 1575 (3472) 1610 (3549) 1620 (3571)
    2 Tire Specs 205/65R16 215/55R17 215/55R17 235/40R19 235/45R18 235/40R19 235/45R18 215/55R17 205/65R16 235/45R18 235/45R18
    3 Fuel Cons. (L/100km) 8.1/5.7/6.9 8.4/6.0/7.3 8.4/6.0/7.3 8.5/6.1/7.4 8.5/6.1/7.4 10.7/7.4/9.2 10.5/7.1/9.0 4.9/4.8/4.9 4.6/4.4/4.5 5.3/5.0/5.1 5.3/5.0/5.1
    4 Fuel Cons. (US mpg) 29.0/41.3/34.1 28.0/39.2/32.2 28.0/39.2/32.2 27.7/38.5/31.8 27.7/38.5/31.8 22.0/31.8/25.6 22.4/33.1/26.1 48.0/49.0/48.0 51/53/52 44.3/47.0/46.1 44.3/47.0/46.1
    SE offers optional 18" alloys but may have been tested with 17" alloys. Interesting to see the difference between XSE V6 and XLE V6 but identical for XSE and XLE 4 cylinder. The XSE models have 19" wheels which you'd think will show up on the XSE.... unless Toyota doesn't expect to sell a lot of XSEs (with ppl who want an XSE opting for the V6 model).
    Also, the LE Hybrid in the US gets 16" wheels on steel rims while Canada gets 17" alloys as standard equipment.
    #1 Tideland Prius, Aug 22, 2017
    mmmodem likes this.
  2. Trollbait
    12,818
    The US site says the LE hybrid gets 16" steel wheels with 205/65R16 tires.
    Do the V6 models get the same transmission as the four cylinders? Different gearing might exacerbate the penalties of the larger wheels and engine. The weight groups can lead to different resistances on the test equipment.
  3. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Could someone put the MPG table with only the hybrid info in the Toyota Hybrids 2018 Camry and Camry Hybrid Official Thread forum/thread?
    I would if I knew how, but I think this would be useful for those who look at that forum/thread. :)
    Thanks!
    52,822
    agreed. thought this was a hybrid thread, sorry.:oops:
  5. Tideland Prius
    16,678
    Huh.... so Canada gets 17" alloys as standard while the US gets 16" steelies. Interesting...
    I don't know if it's the exact same transmission but both engines get an 8-speed direct shift automatic. (2nd-8th gear has a locked torque converter)
    I'll do it.
    Spindifferent likes this.
