2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. bisco
    51,961
    ouch! my wife's 2013 is reporting 45mpg after 10 miles on this tank, and she's no hyper miler.:cool:
  2. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    I've got a couple interesting things coming up.
    I've been leaving to work on time reducing the need for aggressive driving. My current tank shows 57MPG after 300 miles. It should be my best tank yet.
    Also I've got a road trip coming up next week so there will be basically one whole tank that is pretty much all highway driving.
    Spindifferent and Prodigyplace like this.
  3. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Excellent MPG!
    How many total miles do you have on the unit?
    Also, what are your weather temps like now?
  4. CamryDriver
    541
    391
    Arkansas
    I'll check the OD. There is a kinda hard to find button to switch between trip and OD mode. Around 3K I think.
    The temps have been all over the place from as warm as 72F to below freezing. In fact we had that all happen in one day! Temps dropped like a rock. Typically perhaps as warm as mid sixties going to work and maybe low fifties coming home but it has been all over the place. The warmer temps help but so does the less aggressive driving on the trip to work.
    Spindifferent likes this.
  5. Prodigyplace
    12,567
    11,781
    Central Virginia
    On Gen 4 the trip button on left of steering wheel cycles to Odometer
  6. bisco
    51,961
    on our 2013 hycam, they still have a little pushbutton going through the speedo dash.
  7. CamryDriver
    541
    391
    Arkansas
    Today was very weird. The car did fantastic on the way to work, 64.9 MPG displayed! I'm not sure if this was a result of abnormal wind direction or battery SOC but the results were impressive.
    By the time I came home the temps had plummeted to just above freezing and it was raining so the front defog needed to be on. Might have also had an abnormal headwind. My return trip home netted one of the worst results yet at 46.6 MPG.
    I've had trips as low as perhaps 31 MPG on the way to work driving aggressively but my slower return trips home usually always break 50 MPG.
    BTW it took me a while to find the trip/OD button because it is a bit hidden behind the wheel. This even after finding the location in the owner's manual. Got it all sorted out now thanks.
    Prodigyplace likes this.
  8. Prodigyplace
    12,567
    11,781
    Central Virginia
    I find temperature has a large impact on mpg in my Prius.
  9. Trollbait
    12,543
    Same on the 2016, and also the 2013 Sonic. It has probably been kept the same by some because that is were the old mechanical one was at.
  10. Spindifferent
    155
    79
    Central Texas
    269 miles, 51.0 mpg displayed.
    Things are improving! :)
    CamryDriver and Tideland Prius like this.
  11. CamryDriver
    541
    391
    Arkansas
    Got a new complaint. When the sun was lower in the sky the hood had horrible reflections. As the sun has move higher in the sky this problem disappeared and for a while all was good. The sun is higher still and now it reflects off all the shiny things on the dash. My old car had none of this. I like the way the interior of the Camry looks but man it sure sparkles in the sun.
  12. Trollbait
    12,543
    I've found not cleaning the car helps with that.
  13. CamryDriver
    541
    391
    Arkansas
    Today was a good day for MPGs. Made 3 trips in the usual Work, Wal-Mart, Home fashion. Each trip registered over 60 MPGs on the display. The recent bout of cold weather (including a little late season snow) had the tank average under the earlier reported 57 MPG. Today's driving put me back over 57 MPG displayed for the tank so far.
  14. CamryDriver
    541
    391
    Arkansas
    3411 OD
    52.3 lifetime mpg displayed
    464.2 miles this tank
    57.1 MPG displayed (record breaking tank)
    8.631 gallons
    $21.57
    53.8 MPG calculated (record tank, barely)
    6.166% optimistic on the display (also a record, ave has been 4.75%)
    #194 CamryDriver, Apr 12, 2018
  15. CamryDriver
    541
    391
    Arkansas
    3893 od
    down to 51.8 lifetime displayed
    481.9 miles this tank
    48.5 displayed MPG at 70 MPH in 70 degree temps
    9.965 gallons
    $25.30
    48.36 MPG calculated (closest to displayed so far)
  16. bisco
    51,961
    are you looking at fuelly to see how others are doing?
  17. Prodigyplace
    12,567
    11,781
    Central Virginia
  18. bisco
    51,961
    well that's just sad.:unsure:
  19. Prodigyplace
    12,567
    11,781
    Central Virginia
    Only 1 out of 12 exceeds EPA. I suspect that is a new one on its first tank. That tank does not appear in the top chart so was considered an outlier.
  20. Trollbait
    12,543
    163mpg was probably an error in inputting the data.
