2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    "The 2018 Camry Hybrid LE is equipped with a smaller and lighter 1.03 kWh Lithium-ion (Li-Ion) traction battery while the SE and XLE are equipped with a larger and heavier 1.59 kWh Ni-MH traction battery? I asked multiple people why the more expensive, smaller and lighter weight Li-Ion battery was included in the lowest cost LE with no good answer? The only other significant change between the LE vs. SE/XLE is the 16” steel wheels w/ P205/65R16 tires vs. the 18” alloys w/ P235/45R18s. 6 mpg combined difference with a wheel switch and a smaller cap Li-Ion? I cannot answer that question either?"
    Sounds like the car would be very near flawless with the Li-Ion battery, premium interior accoutrements, and some 16" alloys.
    Of course the frigging marketing department would never let anything of the sort happen...
    Actually... that sounds like what the ES 300h should have been.
    51,946
    agreed, the should be an upscale version with the lighter wheels and battery. typical bogus toyota packaging nonsense.
    LasVegasaurusRex likes this.
  3. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    How do you know it is more expensive?
    Trollbait likes this.
  4. Tideland Prius
    16,559
    If it was priced the same, Toyota would've included it. The thinking was they'll sacrifice a few mpg (b/c of the heavier NiMH) and have a lower cost battery to include more features of a regular car.
  5. Prodigyplace
    12,564
    11,779
    Central Virginia
    For the LE I think Toyota Marketing was aiming to meet the EPA economy of the Prius Liftback.
    breakfast and Trollbait like this.
  6. Trollbait
    12,543
    The Li-ion was used to save weight by keeping the usable capacity of the different batteries nearly the same. Once you start adding weight in other areas, the battery weight savings might not be worth the cost.
    The ICE LE and Canadian LE hybrid have 17 inch alloys. The lack of alloys on the US LE hybrid stands out in the class, but did Toyota have 16 inch ones on hand to work with the car.
    Isn't the ES based on the Avalon? The Camry gets upgrades first.
    NiMH is likely cheaper for Toyota. They also have a large investment in it, and like to squeeze all they can out of investments. That's why the Yaris still has a 4 speed automatic.
    Yes, but I'd say Toyota USA since the Canadian LE didn't get the cheap wheels and has a lower rating.
    Prodigyplace likes this.
  7. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Toyota is mostly sticking with NiMH for now including in the next gen Rav4 and even the new compact Lexus UX, Both are eAWD. both coming out around the end of this year. No Li option for either of those anywhere in the world.
    I'll be seriously looking at both of those as a replacement for our other vehicle and will be comfortable with their having NiMH.
  8. Trollbait
    12,543
    No issue with using NiMH. It might actually be better for colder climates.
    Li-ion could improve efficiency by allowing a larger usable capacity in the same space a NiMH pack takes up. Toyota appears to be using it to get a lighter pack, which might only improve results on the tests.
    breakfast and LasVegasaurusRex like this.
  9. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    The stated reason for the inclusion of the Lithium battery in the LE was that the battery would save fuel and therefore money. The people most concerned about saving money would be the people buying the lowest trim model so the LE gets the money saving feature. It actually makes sense. If you can afford the fancy version you can afford a few pennies more in fuel.
    I expect they don't have enough of these packs to go around so they had to make a choice.
  10. CamryDriver
    541
    391
    Arkansas
    Yes I agree which is why fuel economy show up in my list of "The Good".
    I did expect better however since they have adjusted EPA figures twice since I purchased my original hybrid hence the mention also in "The Bad".
    If you check Fuelly the new HyCam is running around 3 MPG better than the previous version yet the EPA highway jumped 15 points from 38 MPG to 53 MPG. Do you see the problem? The old model actually gets what it is rated.
    I expect the previous model was accurate or even a hair under rated. They are reaching a bit with the new model. I'd be happier if the rating was 47 MPG or so highway. It is more a problem with the rating then the car itself.
  11. Prodigyplace
    12,564
    11,779
    Central Virginia
    You would not get the 52 combined with the Liftback either at 70 mph but I regularly keep mine above 55 mpg with highway travel.
  12. Trollbait
    12,543
    Only the LE has a rating over 50mpg. Looking at just Camry hybrid on Fuelly will lump the XSE and XLE hybrids in with the LE. Those are are rated only in the mid 40's
  13. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    That was a quote from the linked article. $/kwh the two chemistries are comparable, but lithium requires extra $$$ for both software and hardware because of different/extra cooling and safety requirements. Most puzzling is the choice to have the same car with both options... it's silly from a manufacturing standpoint.
    Yep, but unfortunately marketing departments have beat out engineering departments for the past decade or so. Which is why we get gigantic "rims" instead of comfy, quiet tires :(
    It has been since 2012, and that's why since 2012 it's been an absolutely awful car.
    Before 2012 it was Camry-based and much better.
    wjtracy likes this.
  14. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    For what its worth, Toyota seems to have avoided some of the trickery that other manufacturers have been employing until very recently.
    Especially for the lower-end makes like Chrysler, Mazda, Subaru etc, the EPA ratings have been far from realistic for nearly a decade.
    They have figured out the EPA test down to a science, so they can do things like change the pedal response curve to get a better EPA number without actually physically changing anything about the vehicle.
    This is most obvious in small, underpowered SUVs like the Crosstrek or the CX-whatever that Mazda is called. They have some model years where no physical changes were made but EPA ratings improved -- only difference was BS software tricks that basically make the pedal do nothing until you floor it. Great for EPA test, not great for surviving the end of the merging lane.
    pilotgrrl and bisco like this.
  15. Prodigyplace
    12,564
    11,779
    Central Virginia
    It is not silly from a user's standpoint. Toyota has said they expect the Prius Li-Ion batteries to have issues in cold climates. They have both options in the Liftback. With some modifications, the software should work in the HyCam too.
  16. Tideland Prius
    16,559
    ...which may explain the battery heater on the 2018 Prius that the new Canadian member was asking in the Gen 4 thread.
    alanclarkeau and Prodigyplace like this.
  17. CamryDriver
    541
    391
    Arkansas
    Yes I see.
    The EPA separates out the LE:
    Browse On-the-Road Fuel Economy Data Camry LE Hybrid
    #237 CamryDriver, Apr 22, 2018
  18. CamryDriver
    541
    391
    Arkansas
    Meanwhile the Prius is doing much better:
    Browse On-the-Road Fuel Economy Data Prius
    The Camry Hybrid and Prius are rated close to the same but the Prius does much better in real life.
    This isn't a huge surprise since the Prius is lighter and slipperier and has a smaller engine.
    Notice my old hybrid is beating EPA more often than not:
    Browse On-the-Road Fuel Economy Data Civic Hybrid
    Out of all the cars listed above only the new Camry is way off the mark. Even the old Camry's rating was close to real world.
    They had a lawsuit against Honda about the Civic not measuring up. I opted out since my Civic got fantastic mileage and was just a great car.
    If there was a similar lawsuit for the Camry I might opt in. The 2018 is wildly overrated, especially the LE.
    #238 CamryDriver, Apr 22, 2018
    pilotgrrl and jerrymildred like this.
  19. Trollbait
    12,543
    It's a 2018. Fuelly won't have year's worth of data. The Camrys tracked there have only been driven in winter.
  20. CamryDriver
    541
    391
    Arkansas
    A fair point to be certain. My Camry is doing very well at slower speeds in the warmer weather. The current tank is around 58 MPG displayed.
    It was 70 degrees during my highway stint. I expect 70 degrees to have been nearly ideal because no AC was required. Any warmer and the AC starts to take a bite out of your efficiency.
    #240 CamryDriver, Apr 24, 2018
