2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I can see how that would work going downhill with increased engine braking putting more of a drag on the vehicle. I can't see how it would work going uphill. How would engine braking come into play in that situation? It seems to me that "shifting" into a "lower gear" would have to add more low end torque. I would think that you would have to increase the contribution of the electric motor to do that.
  2. Trollbait
    12,543
    It allows the engine rpms to go higher for more power.
    Posted this in another thread here.
    royrose likes this.
  3. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    I'm so spoiled by the Camry's 4x automatic windows. I just hit the buttons on the other vehicle and only one window went down because it only has 1x automatic window (the driver's). Holding those other 3x buttons down for a few seconds seems like a lot of work now...
  4. CamryDriver
    541
    391
    Arkansas
    So I've not posted a tank in a while. We didn't keep track during our vacation and I goofed up the first tank when we got back.
    The current tank is running around 65 MPG displayed. The car is being driven normally on the way to work and conservatively on the way home. The new thing is that the AC has been left on the entire time. The AC is affecting the mileage but not nearly as much as it did in my old car (Civic Hybrid). I think if you ran both cars with the AC on the Camry might actually get better mileage, which is amazing.
  5. CamryDriver
    541
    391
    Arkansas
    I tried out "Sport Mode" for the first time while going down a big hill. You definitely gain the ability to control the level of engine braking. Normally in "Normal Mode" the car will speed up to 60 MPH while going down this particular hill. Sport mode allowed me to (variably and greatly) increase the level of engine braking thereby decreasing the maximum speed while going down the hill.
    I couldn't tell if the engine was coming on. The effect was much smoother than the "Jake Brake" incident I posted about earlier:
    HyCam noisy going down hill | PriusChat
    ...so the engine may not have been turning. It is a little annoying that the car lacks a tachometer so I can't say for sure.
    The primary use for this would seem to be to save wear and tear on the brakes. Sport Mode seemed to generate less regen. Normally in "Normal Mode" the car would have a full charge at the bottom of the hill. I typically switch from ECO Mode with AGC to Normal Mode to increase the drag. In Normal Mode the engine does not turn and the generator causes all the drag and the battery ends up full most every time. In Sport Mode the battery was not full at the bottom of the hill leading me to suspect that maybe the engine was used to cause more drag resulting in less rather than more regen.
    The "Jake Brake" incident also seemed to generate less regen.
    LasVegasaurusRex likes this.
  6. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    after over a year with the i3 I don't think I'll ever get used to the way it drives. I hate "1-pedal driving"
    never was a fan of "sport modes" or any other such nonsense. I love the way my Camry Hybrid drives, sounds like they improved on it in the new one :)
  7. bisco
    51,969
    the second gen gets a little better gas mileage for us than the first, and the trunk is larger. can't wait to trade in on the third gen.
    Tideland Prius likes this.
  8. Tideland Prius
    16,559
    If you're talking about the Camry Hybrid, this is the 3rd gen. (2007-2011, 2012-2017, 2018+)
    Prodigyplace likes this.
  9. bisco
    51,969
    right, i can't wait to trade in our 2nd gen for the third.(y)
  10. CamryDriver
    541
    391
    Arkansas
    So I used the "B" mode/ Sport shifting while going down the big hill and paid special attention to the needle on the left most gauge. The needle momentarily dipped lower (seemingly indicating more battery charging) with each "down shift" but then it went back to about where it would be in NORMAL mode shortly thereafter. Still not sure if it increases or decreases overall charging and still not sure if the engine spins.
  11. CamryDriver
    541
    391
    Arkansas
    New tank (finally, have missed a few)...
    Lifetime displayed MPG 55.4 (was down under 55 during our vacation at highway speeds)
    Trip 709.9 miles with 93 miles range left. The car could go 800 mile if I wanted to push it.
    65.4 MPG displayed tank
    $28.44
    11.115 gallons
    63.9 MPG calculated
    This tank had the AC on the entire time so I was perfectly comfortable. Driving to work was done at normal speeds while driving home was more conservative.
    I've done better than 80 MPG in my previous hybrid but that was with the AC OFF during the hottest part of the Summer and getting lucky with some traffic, lights and weather. This also involved leaving early for work so trips both directions were slow.
    This tank in the Camry was impressive in that I didn't go to much trouble at all and still got good mileage.
  12. CamryDriver
    541
    391
    Arkansas
    Got a new phone, one that actually has data (unlike the previous phone). I'll be checking out the Entune system and reporting back. So far I'm not seeing anything I couldn't live without.
  13. CamryDriver
    541
    391
    Arkansas
    I don't have the energy to describe how bad Entune and especially Scout Link are. I used Scout Link once on a old road that has been there for at least 20 years. It told me to take a hard right (specifically a "hard" right) at a time when I needed to take a left to get home. Once I went left the thing went completely nuts and started naming off roads on the far side of the subdivision, this after I was already on my own street with a block to go before reaching my house. Terrible! Also no maps are available while on Bluetooth, just wacky and incorrect turn by turn directions.
  14. azjerry
    azjerry Junior Member
    29
    Phoenix
    I agree with the comments about Scout. Absolutely horrible. Get a Garmin or mount you phone and use Google maps on your phone. Entune is OK but nothing special. Android Auto is much better and could be run on a mounted phone as well.
  15. CamryDriver
    541
    391
    Arkansas
    There was an address mix-up that was partly my fault so maybe Scout Link isn't quite as bad as I was claiming.
  16. azjerry
    29
    Phoenix
    No, really, it is that bad. ;)
  17. LasVegasaurusRex
    234
    110
    Las Vegas, NV
    I switched to Waze a few years ago and never looked back.
  18. azjerry
    29
    Phoenix
    I've been quite happy with Google Maps.
  19. CamryDriver
    541
    391
    Arkansas
    I've got a Garmin which is okay but it is mounted a little low to be convenient. I leave it disconnected most of the time and will only use it if we are on vacation. I don't need it to get to work.
    We tried Waze offline and didn't have much luck with it. Google Maps has a decent offline/wifi only mode. Waze might be fine with data.
    I just got data on my phone so Google Maps or Waze should work well.
    The biggest advantage of Scout is that it is right on the dash on a nice easy to see screen. That might be useful even if the navigation is terrible. One can just use it for the map and leave the navi part off.
    Of course the best thing would be for Toyota to allow Android Auto to function. Pipe dream...
    I love my car but I'm mad at Toyota for hamstringing the infotainment with their crappy apps.
  20. azjerry
    29
    Phoenix
    I should have mentioned that I have my phone on a Proclip mount that puts it in a very easy to see location.
