2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    52.5 mpg displayed tank
    510.5 miles
    56.2 lifetime displayed
    12,047 OD
    $21.88
    10.423 gal
    48.98 MPG calculated
    Cold weather has the lifetime displayed in retreat.
  2. Tideland Prius
    16,559
    Still. What other non plug-in cars that isn't named Prius, is capable of almost 50mpg all year?
  3. CamryDriver
    541
    391
    Arkansas
    Good point...Maybe the Ioniq?
  4. Tideland Prius
    16,559
    Oh right lol. Yes Ioniq.
    But the Camry is miles bigger (or is that cubic feet?) than both the Prius and Ioniq.
  5. CamryDriver
    541
    391
    Arkansas
    Well let us see.
    Camry EPA Interior Volume 115.0 cu.ft.
    Prius EPA Interior Volume 117.7 cu.ft.
    Ioniq EPA Interior Volume 122.7 cu.ft.
    Nope...
    The Camry is about 500 lbs heavier and makes a fair bit more power. I think of the Camry as being quite a bit more luxurious.
  6. Tideland Prius
    16,559
    You need to compare passenger volume only. (i.e. excluding all the volume behind the rear seat) That’ll drop to 93.1 for the Prius. The number you’re quoting above includes cargo since there’s no hard distinction or divider between passenger and cargo area such as one would find in a sedan. The Ioniq would be around 96 cu ft of passenger only volume.
    I mean, sit in a Prius. I don’t think you’ll be convinced it’s larger than a Camry. The Camry is sitting on a full size platform and it’s not that wasteful of a design such that it compromised passenger volume.
  7. Trollbait
    12,543
    Camry EPA Passenger Volume 100 cu.ft.
    Prius EPA Passenger Volume 91 cu.ft.
    Ioniq EPA Passenger Volume 96 cu.ft.
    I pulled those off Fueleconomy.gov, which rounds the decimal.
  8. bisco
    51,946
    camry is much more lux than prius, i haven't driven an ion
  9. Tideland Prius
    16,559
    Yes, definitely. The Camry is on a higher standard than the Prius for interior accommodations.
  10. bisco
    51,946
    quieter and more powerful too. if the new one is 50 mpg, that's tough to beat
    Tideland Prius likes this.
  11. CamryDriver
    541
    391
    Arkansas
    Looks like the one year mark is coming up the 23rd of December. I expect the lifetime average to be 56 MPG displayed which would be about 53.5 MPG calculated at the pump.
    Tideland Prius and Spindifferent like this.
  12. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    That's incredible really.
  13. CamryDriver
    541
    391
    Arkansas
    This will be the closest tank to the 1 year mark.
    52.6 MPG displayed tank
    590.9 miles
    56.0 lifetime displayed MPG
    12,638 OD
    $22.97 (under $2/gal)
    11.848 gallons
    49.87 MPG calculated.
  14. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ....But there is not really a good way to compare PAX volume.
    PAX volume on a sedan/Camry should be accurate as stated.
    But EPA allows liftbacks some freedom to split the total volume to show more cargo space, if they so desire.
    The fallback would be to go to Europe to see a more accurate PAX volume, but Europe does not seem to require that spec.
    I do think the initial Gen4 spec list from Toyota you provided a long time ago showed the volume numbers both "straight":and via "EPA method".
  15. CamryDriver
    541
    391
    Arkansas
    51.8 MPG displayed
    509.2 miles
    55.8 lifetime displayed (down 2 tenths)
    13,147 OD
    10.500 gallons
    $19.94
    48.5 MPG calculated
  16. bisco
    51,946
    got 40.6mpg at the pump from boston to virginia in our 2013 yesterday. mostly 60-65 mph, temps in the 30's, 506 miles.
    dash was reading 42.8
    seriously considering upgrading to 2019 this fall when the 20's come out.
  17. CamryDriver
    541
    391
    Arkansas
    I'm enjoying mine. A guy at work is a big fan of the last generation. The new model is smaller or it is harder to get in back or something. I think this is true.
    He also thinks one version has rear wheel drive which I'm not so sure about.
    I like where they located the batteries. I think the 12v is under the hood now but you should double check.
  18. bisco
    51,946
    interesting. we rarely have anyone in back. trunk is bigger, no?
    larger back seat pass through as well?
  19. CamryDriver
    541
    391
    Arkansas
    I've got no point of comparison but yes, on the 2018 the batt is under the seat, the seatbacks fold down and the trunk is great. There is a spare which is rare!
    Full tank was downsized to 13 gallons.
  20. CamryDriver
    541
    391
    Arkansas
    We do question its suitability for taxi use, however, as both front and rear seats are about an inch lower than before, and entry into the rear compartment requires negotiating a small opening between the rear-door pillar and the corner of the seat cushion.
    2018 Toyota Camry Hybrid first drive
