2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. bisco
    51,946
    It’s not about money for us, it’s all about mpg. When the time comes, I’ll delve in as deeply as possible.
    I do like the ride of our current wheels
  2. Trollbait
    12,543
    Yep, instead setting the max gear the automatic can shift to, it sets the amount of engine and transmission braking done on the car for the hybrid. In terms of a Prius, it is variable level B 'gear'.
    You have the ability for it on the LE, but just through the gear shift when it is in the S position. Not only does the paddles make it more convenient, but you also do the shifting while in D.
  3. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    Yeah if I pull the gearshift to the left I can "shift" but I don't really use that feature. It seems more efficient to use regenerative braking than engine braking.
  4. Trollbait
    12,543
    I down shift to control speed on down slopes. Many here would quickly fill the battery of the 2005 Prius when sticking to just regen.
  5. CamryDriver
    541
    391
    Arkansas
    What a difference a day makes. Managed 56 MPG on the way to work in 25 degree temps. I suspect being garage kept helped this figure from being lower. Got a dismal 49 MPG displayed on the way home with temps in the upper teens. This in spite of driving conservatively like I have been for the last several days.
    This is quite a drop in both temps and MPGs!
  6. Trollbait
    12,543
    And yet my news feed has been full of articles on how BEVs lose range in the cold.
  7. CamryDriver
    541
    391
    Arkansas
    I bet they do. The cold stiffens the lubricants and makes the car harder to push.
  8. bisco
    51,946
    after 200 miles, temps shot up to the 80's, a/c use. i'm down to 50 mpg on the dash. airport run tomorrow, that will probably kill it
  9. CamryDriver
    541
    391
    Arkansas
    Crazy new tank with temps from the teens to sixty five and displayed trip MPG averages from the forties to the eighties.
    Tank 551.1 miles
    55.8 MPG lifetime displayed
    55.8 MPG tank displayed (tied with lifetime)
    13,698 OD
    $20.40
    10.415 gal
    52.91 MPG calculated tank
  10. CamryDriver
    541
    391
    Arkansas
    Mileage is on the upswing thanks to a few things, namely warmer weather, leaving for work 5 minutes sooner, and turning off the climate control unless it is really needed.
    New tank:
    542 miles trip
    57.6 MPG displayed tank
    55.9 MPG lifetime displayed
    14,240 OD
    $21.27
    9.851 gallons
    55.0 MPG calculated
  11. CamryDriver
    541
    391
    Arkansas
    So I've perhaps learned something new just recently. It seems that if one leaves the climate control off and does not exceed 10 MPH the Camry will take longer to turn on.
    Previously in cooler weather I couldn't get out of the parking lot before the engine would kick on. I think part of the reason was that I'd exceed 10 MPH. Today I got a good way down the road but it was warmer so that may not be the whole truth. Still it seems like the 10MPH thing is real. More is testing needed to know for sure.
    Under 10 MPH is not a very practial speed range to be useful but it is still interesting to discover.
  12. Trollbait
    12,543
    It is probably there for the same reason the original Prius had an EV button, to allow the car to moved between parking spots, out of the garage for the mower, or not disturb neighbors.
  13. bisco
    51,946
    that's exactly how ours works. it's mostly useless, but if the car is warm enough, you can move it in or out of the garage without the engine starting.
    driving it in ev will only kill your mpg's
  14. CamryDriver
    541
    391
    Arkansas
    New tank.
    OD 14,484
    Trip was reset but 14,848−14,240 = 608 miles
    Tank average 56.1 MPG
    Lifetime 55.9 MPG
    11.374 gallons
    $26.15
    53.5 MPG calculated
  15. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I priced out a new camry hybrid xle. I was surprised how expensive it got.
  16. padroo
    padroo Senior Member
    2,763
    2,252
    I noticed the last time I was in the dealers showroom how upscale the new Camry's are now, especially the interior.
  17. CamryDriver
    541
    391
    Arkansas
    I really like the interior.
  18. CamryDriver
    541
    391
    Arkansas
    New tank, before road trip.
    OD15,279
    56 MPG lifetime displayed
    430.6 miles trip
    62 MPG displayed tank
    $17.81
    7.243 gallons
    59.45 MPG calculated
  19. CamryDriver
    541
    391
    Arkansas
    There is about 900 miles of highway driving spread out between the next 2 tanks.
    Displayed mileage was not very good, perhaps 47 MPG displayed at 70 MPH in fairly warm weather but not warm enough to need AC.
    15,741 OD
    461.7 trip
    53.3 MPG displayed tank (includes slower driving)
    $21.82
    8.872 gal
    52 MPG calculated tank
  20. CamryDriver
    541
    391
    Arkansas
    16,320 OD
    579 miles trip
    55.8 MPG lifetime displayed (down 2 ticks)
    52.9 MPG tank displayed
    $29.17
    11.674 gallons
    49.6 MPG calculated tank.
