2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. Tideland Prius
    16,559
    That’s still pretty amazing that a Camry can get 55 lifetime mpg.
  2. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
  3. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Wow that really is great MPG for a larger vehicle...especially since it appears you do quite a bit of freeway driving..correct?
    I'll be interested to see how the hybrid Corolla fares in the real world. If it is similar to the EPA, the Hycam seems like the better vehicle because it has so much more room than the Corolla. The new Corolla just looks too small for those with a family, etc...
  4. Tideland Prius
    16,559
    The difference is that the 2018 Camry was launched with the Entune 3.0 headunits. Our units cannot be retrofitted because they're of a different hardware.
  5. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    I only travel on the highway a few times a year. The car is intentionally driven to get high MPGs most of the time, highway travel or running late to work being the exceptions. Hopefully the car will have one tank that breaks 70 MPG this coming Summer. Got close last year but didn't quite make it.
    The current tank was on track for 70 MPG but a couple cooler days has the display in the mid sixties. Heat is a friend of mileage.
  6. CamryDriver
    541
    391
    Arkansas
    Calculated record tank from June of 2018 is the number to beat. I fully expect to eclipse that number this Summer by just leaving for work 5 minutes earlier.
    Tideland Prius likes this.
  7. CamryDriver
    541
    391
    Arkansas
    New tank is looking pretty good!
    594.1 miles trip
    69.3 MPG displayed tank
    56.2 MPG displayed lifetime (up 4 tenths from last tank)
    16,914 OD
    $22.74
    8.751 gallons
    67.9 MPG calculated tank, not bad...
    jerrymildred and Tideland Prius like this.
  8. Tideland Prius
    16,559
    That's insane... especially when you consider that the Camry is a pretty large car.
    jerrymildred likes this.
  9. CamryDriver
    541
    391
    Arkansas
    20190516_151458.jpg Got a pretty good tank going 74 MPG displayed after just under 300 miles.
  10. Tideland Prius
    16,559
    Those are Prius Prime numbers!
  11. bisco
    51,946
  12. CamryDriver
    541
    391
    Arkansas
    Lost a couple ticks for a while but then gained them back and more. Pretty sure this is a record tank so far. It is stormy today so it is likely I'll lose some tenths.
  13. farmecologist
    1,958
    1,799
    Southern MN
    So any insight as to why your MPG is so good? What kind of driving do you do? I'm not doubting you but honestly your numbers seem to be in the 'too good to be true' category unless you are doing 'extreme hypermiling' or some such thing. (y)
    If you are not doing 'extreme hypermiling' then the HyCam is definitely going on my short list! (y)
    Also, how does the HyCam do on the freeway? I have suspected that it may do better than the Prius on the interstate and such.
    Thanks!
  14. CamryDriver
    541
    391
    Arkansas
    Yes, there are several factors including hypermile style driving and not driving during rush hour
    I believe a Prius would be pushing 100mpg if driven in a similar manner.
    On the freeway the Hybrid Camry has been getting 45 to 50mpg at 75mph with AC in use. I believe a Prius would do just a bit better on the interstate.
    While the Camry is no match for a Prius in terms of mileage it is nice, comfortable and more powerful.
    The Camry has been no match for my old Civic Hybrid which I drove 1000 miles on a tank at over 80mpg.
    farmecologist likes this.
  15. CamryDriver
    541
    391
    Arkansas
    While the Civic got better MPGs and was a good car, the Camry is just a much nicer car. No comparison really.
  16. CamryDriver
    541
    391
    Arkansas
    The Accord is a more direct competitor to the Camry than the Prius. The Accord Hybrid is worth a look IMO.
  17. CamryDriver
    541
    391
    Arkansas
    I struggled to achieve 70 mpg on the way to work into strong winds but those same winds made for an incredible trip home.
    Tideland Prius and farmecologist like this.
  18. CamryDriver
    541
    391
    Arkansas
    RECORD TANK!
    75 MPG displayed tank
    523.5 miles trip
    56.7 lifetime MPG displayed
    17,438 OD
    $18.22
    7.29 gal
    71.8 MPG calculated, RECORD!
  19. Tideland Prius
    16,559
    You gotta have the most ideal commute to pull those numbers off! But definitely something for other TCH owners to aspire to.
  20. CamryDriver
    541
    391
    Arkansas
    My commute is 16 miles of mixed city/back roads/highway driving in roughly equal parts. The big advantage is working a non-rush hour schedule. The drive is long enough to mostly overcome the startup/warm up cost.
    One disadvantage of my commute is that it is into the wind when the wind is stronger and with the wind when the wind is weaker. It would be better if I lived on the other side of where I work in this regard.
    Not to brag but I have been driving for mileage for over a decade. Started out getting nearly 40MPG in a Corvette. I was one of only 2 drivers that got over 80 MPG in a Honda Civic Hybrid, the other being RJBarlow.
    The Camry requires some different techniques but I'm finally getting the hang of it. The other 2 cars were not entirely safe to drive this way because they were not designed to be driven with the engine off. The Vette was very hard to drive without power steering for example. The Honda only lost functionally for a few seconds before the electric power steering was available again after a "FAS". The Camry shuts off automatically so no FAS is required. The Camry remains fully functional 100 percent of the time.
    Trollbait and Tideland Prius like this.
