2018 HyCam amateur review and ongoing blog
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Jan 22, 2018.
  1. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    A black hood looks great on this car:
  2. Trollbait
    12,543
    Just in case I wasn't clear, my suggestion wasn't to wrap the entire hood. It was to just put a strip of material on that shelf of hood at the base of the windshield that is causing the reflection.
  3. CamryDriver
    541
    391
    Arkansas
    Yeah, I got that. A strip would work but has 3x difficulties as I see it.
    1) It would be hard for me to make a strip look good because of the curve of the hood, it would take a professional. My professional assumed we were doing the whole hood.
    2) A hood strip or wrap would be exposed to the elements so it seems like it would not last as long as indoor behind glass tint.
    3) A strip would have an exposed leading edge that might make it prone to peeling.
  4. CamryDriver
    541
    391
    Arkansas
    Wrapping the whole hood eliminates this issue, however a full wrap would still be exposed to UV light and wouldn't last as long as tint behind glass, I suspect.
    #104 CamryDriver, Feb 9, 2018
  5. Trollbait
    12,543
    Yes, you would need a steady hand with the razor blade when trimming it. I did the inside of the Chevy bowtie and center caps to the wheels, so didn't have a blade near the paint.
    As long as the vinyl used is for exterior applications, it should last years. I had it on the Sonic for a couple years before getting rid of the car, but no issues.
    Another option is to paint that strip with Plastidip or similar. If you mess up, or just don't like it, it can be peeled off.
  6. CamryDriver
    541
    391
    Arkansas
    The strip is on the windshield. I don't like it. My mistake was in trying to only cover the really bright part. As a result some of the white hood is visible over the top of the strip but in an uneven way. I think the strip is straight but there is a complex interaction between the driver's seating position, the strip and the hood. If I slouch down a bit the whole hood is covered and it looks a lot better. I think I'm going to have it redone with a bigger strip. This picture shows what it looks like at the height of my eyes.
    #106 CamryDriver, Feb 10, 2018
  7. CamryDriver
    541
    391
    Arkansas
    I like this better, where you can see the hood all the way across.
  8. CamryDriver
    541
    391
    Arkansas
    I like this best, where the hood falls completely in the strip.
  9. CamryDriver
    541
    391
    Arkansas
    Went driving for the first time in bright sun. The windshield strip helps but the dang sun glare is still too bright. I'm going to need a strip on the hood or a wrap. This is the first car I've even owned with such a problem. Several previous vehicles were black but I've had white and metallic silver with no glare issues in the past.
  10. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
  11. CamryDriver
    541
    391
    Arkansas
    For me none of the apps work at all because my phone does not have data. As I understand it there will be a map app available which will be ScoutLink. The car has GPS hardware but there are no maps built into the car. ScoutLink uses your phone's data to download maps. This really isn't so bad, for 3 years. The kicker is that after a free 3 year trial period Toyota plans to start charging for ScoutLink. They want you to pay them for the privilege of using your data to power their app!
    It turns out I really like the Entune 3.0 features that do work with my phone. Called the wife last night using only voice commands and it worked brilliantly. I like the home screen that shows the time, power flow diagram, radio information and phone stuff all at the same time.
  12. CamryDriver
    541
    391
    Arkansas
  13. CamryDriver
    541
    391
    Arkansas
    Some quotes from reviews:
    "Horrible horrible horrible! Just got my new car and am ready to punch in the damn screen."
    "Don't like this app at all. Comes nothing close to Google maps. It's sluggish at best"
    "This is the worst navigation app link ever! I can't believe Toyota has installed this BS"
    #113 CamryDriver, Feb 14, 2018
  14. Stevevee
    821
    224
    Vermont
    I don't know why Toyota does this crap. I figured the new ones would have the basic app I got in my 2013 Prius V. Works for me, and no phone required. So apparently, this is the replacement.
    Dynamic Navigation 15
    Dynamic Navigation provides you with the most up-to-date map data, routes and POI on its embedded system. Currently available with Entuneā„¢ 3.0 30 Premium Audio.
    Hard sell.
  15. CamryDriver
    541
    391
    Arkansas
    Toyota has some specific language they use to identify the 2 types of navigation they currently offer. The one I have is called "connected", meaning you need your phone's data to make it work.
    There is another type that is only available in the higher end models they call "Integrated". Integrated Nav actually has maps installed in the car that work independently from your phone. They want thousands of dollars more for a vehicle with this feature. I can get a Garmin with lifetime map updates for less than $200, so that put an upper cap on what I'm willing to spend on such things.
    Trollbait likes this.
  16. Stevevee
    821
    224
    Vermont
    That's what gets me. Even in Corollas you had the onboard navigation, which is integrated, like I have on my 2013 Prius v three, and my previous Camry. I've used in on many trips, and it did what I wanted. Not fantastic, but fully capable, and no extra fees. Toyota is truly one of the worst with technology, and has only recently said they will add Apple Play later this year.
    We have another year until the lease is up on the Camry Hybrid. Looks like we'll have to start checking out other cars.
  17. Trollbait
    12,543
    I don't understand how the car companies are still able to charge thousands for built in navigation systems?
    Stevevee likes this.
  18. Prodigyplace
    12,564
    11,779
    Central Virginia
    Especially when many people find them unusable anyway. Phones or standalone GPS are much better for lower cost, on a majority of situations.
  19. Stevevee
    821
    224
    Vermont
    A lot of people, including me, hate add ons in the car.
  20. Prodigyplace
    12,564
    11,779
    Central Virginia
    A few are useful but many times you need to get the extras to get what you want.
    My son had to get navigation in his 2015 Prius v in order to get the Remote Start feature he wanted. I think he quit trying the Nav after the first week and went back to his trusty Garmin unit.
