2018 Interior fuse box
Discussion in 'Gen 4 Prius Technical Discussion' started by NickerNerd, Jan 13, 2020.
  1. NickerNerd
    NickerNerd Junior Member
    Ontario, Canada
    Good day,
    Does anyone have a pic of the interior fuse box, with the cover off, by the driver's side? I'm looking to hardware my dash camera and would like to know ahead of time if there is a vacant 15amp spot. 2018 Prius. Big thanks!
    crustyfibers likes this.
  2. NickerNerd
    Ontario, Canada
    Making progress but still need a little assistance from the forum.
    A friend helped me locate and get a few pics of the interior fuse box, I've added them here. I 'm planning to plug the 15amp fuse into one of the existing slots and just have 3 questions:
    Q: Does anyone know which side of the fuses is the hot side?
    Q: Does the empty slots have any voltage, a 15 or 20amp?
    Q: By plugging the dash cam fuse in, to lets say, the rear wiper, will the rear wiper still work?
    Thanks chat!
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You need to use a 12v test lamp to check the your first two questions (clip to ground) and the third question, if you plug the dash cam fuse into wiper slot the fuse is likely to blow if you have the dash cam and the rear wiper on at the same time.
    alanclarkeau likes this.
  4. ChapmanF
    19,037
    How much juice would a dash cam use, if a dash cam could use juice?
    kithmo and krmcg like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Same as a woodchuck.;)
  6. ChapmanF
    19,037
    Next time I need an internet band name, Electric Woodchuck might be it.
    alanclarkeau and kithmo like this.
  7. Giant81
    Giant81 New Member
    SW Wisconsin
    2018 Prius
    Two Eco
    If I have a Two Eco and no rear wiper, I suspect the slot is still there and empty, would it still have power to that port of the panel? and if so, could I just wire to the back of the panel so it looks factor instead of the double fuse plug things the cam came with?
