2018 Prime Advanced 15" Alloy Wheels regional only?
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Jul 23, 2018.
  1. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    When I ordered my 2018 Prius Prime Advanced I wanted the 15" Alloy Wheels and was told it was not orderable in the system. I thought that was strange as the toyota.com did show the option. I did not press the point but now I wonder why I could not order the $1K option?
    Has anyone in the Midwest successfully had their 2018 Prius Prime outfitted with the 15" Alloy Wheels as a Port Installed (not Dealer installed) option?
    Thanks.
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    When I got my 17 they were an order from factory only part.
    If you remove the hubcaps, there’s a perfectly respectable set of alloy wheels underneath, you just need the center caps from a yarris to cover the hole, they are also very light in weight.
    schja01 likes this.
  3. LoliKami
    LoliKami Junior Member
    31
    Los Angeles
    Yes it's already alloy.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Do you mean to pay $1K extra to have them swap the rims from OEM rims and cover? If you do that, would you receive OEM rims and covers with your car? I would just order the rims from any Toyota dealer and swap tires and TPMS on them. You could use extra OEM rims for your winter tires then.
