2018 Prime - Rust on Hatch Handle
Discussion in 'Prime Main Forum (2017-2022)' started by JeremyL, Mar 10, 2019.
  1. JeremyL
    JeremyL Junior Member
    New York
    2018 Prius Prime
    I purchased my Prime Plus in August. It has now gone through it's first winter with salt in the Northeast.
    I noticed today that there is rust beginning to form in the handle area of the hatch. There is a piece of metal in that area that is not showing visible rust but is all bubbled (clear sign that rust is forming below the paint).
    I see some posts on this from 17 but nothing more recent and no resolution. Is this still a common problem? Any clue what the fix is?
  2. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    curious what this looks like - could you post a picture?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    There's another fairly long thread on that subject somewhere here. Apparently quite a few people have had this happen including the previous owner of mine. Like this:
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    You are correct, nothing has been done by Toyota to remedy this problem AFAIK. The issue has been brought up to the Toyota headquarter (both US and Canada), and they know this problem exist. I have been on a waiting list to replace the handle parts as soon as a new (and hopefully improved) material parts becomes available, but it has been almost 8 months.
    When weather brakes, I am going to try to remedy it DIY. Probably taking the parts off and applying rust proof paint of some sort.
    Here is the link to the original thread on 2017 PRIME.
    Rust on rear hatch handle | PriusChat
    Mendel Leisk and jerrymildred like this.
  5. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Had the same rust on mine. The dealer repaired it under warranty.
    HPrimeAdvanced and Montgomery like this.
  6. Salamander_King
    11,024
    8,977
    New England
    Repaired by replacing with the same parts made of the same material? Have you had the same issue after this winter yet?
    HPrimeAdvanced likes this.
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    These are the kinds of issue the AWOL Prius Team need to see, but apparently, Toyota US is not interested in customer support after they have your money.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Nice! I just looked at the corrosion warranty and it said it's for perforation (rust through), so I wouldn't expect them to replace it. Maybe I should check on that before I take it apart and treat it myself.
    HPrimeAdvanced and Prodigyplace like this.
  9. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Had body shop repaint it.
    Looks like it is starting to rust again.
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    I lived on a small island for nine years. This stuff is the best:
    benagi likes this.
  11. Salamander_King
    11,024
    8,977
    New England
    So, it was never replaced? Toyota just reimbursed you for the cost of painting it under warranty?
  12. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    The dealers body shop repainted it. It is starting to rust.
    Salamander_King likes this.
  13. Salamander_King
    11,024
    8,977
    New England
    Well, that makes me wonder how hard it is to replace it. I was thinking if I can remove the piece easily, then repair it DIY. If it is super difficult, I may have to wait for Toyota to come up with a replacement parts.
    HPrimeAdvanced and jerrymildred like this.
  14. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    It doesn't look like an easy part to replace. I believe the rear hatch is a carbon fiber material.
    jerrymildred and Salamander_King like this.
  15. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    I checked mine with a magnet and found it has a plastic trim shell surround, but the rusted section jerry showed is actually behind the surround. Might be easiest to just brush on a rust converter/stabilizer or preemptively slap a quick protective coat of paint on it.
    Montgomery likes this.
  16. jerrymildred
    11,517
    14,164
    Tampa, FL
    That thought crossed my mind, but it wouldn't help the sides or the back. I wonder if anyone has popped the panel off of there yet and knows where to safely pry. I'm sure it's not too hard, but it is a little scary. If the handle has a plastic coating the coating would have to be removed in order to properly treat the rust.
  17. Trollbait
    12,806
    The difference material thickness likely means a different part than what the gen4 uses.
    If the Prius handle isn't having any issues, looking into whether it could be made to fit the Prime may be quicker than waiting for Toyota.
  18. Prodigyplace
    12,710
    11,848
    Central Virginia
    You mean this?
    Switch - Toyota (84840-47040) | Toyota Parts
  19. Trollbait
    12,806
    Whichever part that is rusting.
    Since it hasn't been mentioned here, I'm working with the assumption that the issue isn't effecting the plain old Prius model. Thus the part isn't one shared between them. This looks like a strip a steel to give some extra reinforcement to the carbon fiber around the handle area.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    I just went out to my car & verified. The Gen 4 switch is totally different. The switch itself only has rubber exposed.
    #20 Prodigyplace, Mar 13, 2019
