2018 Prius 2 rough ICE start
Discussion in 'Gen 4 Prius Main Forum' started by nikholys, Jun 21, 2018.
  1. nikholys
    nikholys Junior Member
    Los Angeles
    2018 Prius
    hi there. Has anyone experienced rough ICE starts? It happens after AC use and car turned off. Didn’t expect issues so soon, car has only 650 miles. Thx
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry I can't offer any sound advice, but welcome to Prius Chat.
    There have been various posts on here about the symptoms you have experienced although I can't find any to quote for you. Somebody Stateside is bound to come back to you before very long.
    nikholys and alanclarkeau like this.
  3. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Was that a pun? :LOL:
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oops! Genuinely unintended, nice catch. (y)
    alanclarkeau, krmcg and Since2002 like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I think it's normal - if the engine is cold. Think of a "normal" car, you'd hop in, turn the key - and, it's not what you'd call smooth - the starter turns, the computer (or choke/accelerator pump/ignition retard on old cars) sorts out what is needed as far as timing, ignition and fuel supply to kick the engine into life. Even more exciting in a diesel.
    PRIUS, [assuming there is Hybrid Battery charge and that the heater or A/C isn't intervening] instead, starts with some very quiet space-ship like whistles, clicks and whimpers, you put in reverse and it reverses out your driveway silently except for the crushing of leaves in the driveway.
    You drive along the avenue, still it's in silent EV mode, the battery decides it's helped you along enough, or you've put your foot on the accelerator more than gently - and it decides THEN to start the cold ICE. Basically, it connects it to the transaxle and it spins - while concurrently, the injectors squirt petrol (I'd assume a richer cold-start ratio), the ignition starts firing - and it's noticeable.
    So what you're experiencing is the same as starting a cold engine - but while you're driving along in a relatively quiet car. After that first start, you'll barely notice the engine starting and stopping - just the first time - but it's stopping and starting continually.
    RCO likes this.
  6. bisco
    52,448
    really? the gen 4 engine is experiencing rough start issues? wow.
  7. alanclarkeau
    7,045
    7,593
    I wouldn't call it rough.
    It's just like the normal start on any normal ICE car - just that it happens while driving along silently, not when you turn the key. It's noticeable first time after starting/re-starting.
  8. bisco
    52,448
    gen 2 and 3 aren't. (except the gen 3 egr problem)
  9. alanclarkeau
    7,045
    7,593
    I could feel it when I test drive a Corolla HYBRID which uses pure Gen 3 ICE & Hybrid tech - I had been talking to the salesman about it and it was noticeable - but we were listening for it.
  10. bisco
    52,448
    i can hear and feel the engine come on, but my wife can't. but i think there o/p his talking about something rougher, since it is already warmed up, and only happens after a/c use and the car turned off.
    nikholys likes this.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Do you shut the car off while the ICE is still running? It is better to let the ICE shutdown on its own before powering off the car. Exactly what do you mean by "rough" ICE starts? Does it shake/clank upon starting?
    RCO and kithmo like this.
  12. alanclarkeau
    7,045
    7,593
    I've never worried about that - but I generally turn the Climate Control OFF when I stop, particularly overnight.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Rough starts usually occur (on the next start up) after the car has previously been shut off, whilst the engine was running, before the first warm up cycle had completed. This is a well known feature of some fuel injection systems, I had a Ford Mondeo which did the same.
    RCO and FuelMiser like this.
  14. bisco
    52,448
    i had not heard this about the gen4. that's too bad, i thought they might have solved it.
    has anyone reported it here?
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It's much less noticeable on the Gen 4, i.e. nowhere near as rough and it goes away after a few seconds.
    bisco and Tande like this.
  16. Mendel Leisk
    41,971
    Obviously still under warranty, and assuming you'll draw it to their attention: post what the dealership says.
  17. Tande
    Tande Active Member
    550
    337
    Mich.
    Yup.....that's been my experience also......:(
  18. bisco
    52,448
    amazing toyota can't fix this problem, must be the quest for mpg's.
    our hycam doesn't do it, i wonder if the new one does.
    RCO and Tande like this.
  19. alanclarkeau
    7,045
    7,593
    I think Camry has more sound insulation - PRIUS' claim to fame is light weight, max fuel economy - and the sound insulation has only been applied where it's really needed.
    I figure they're not concerned about a fairly minor noise/vibration which happens once for 2 seconds after every start - better to put that kg of insulation where it's going to have more usefulness.
    RCO likes this.
  20. bisco
    52,448
    if it's just 2 seconds after every start, i would agree. kithmo is saying differently. hopefully, o/p returns to clarify.
