2018 Prius C plastic roof rails
Discussion in 'Prius c Main Forum' started by Jimmyb426, Sep 19, 2017.
  1. Jimmyb426
    Jimmyb426 New Member
    Victoria BC
    2017 Prius c
    So I just got my 2018 C, I was disappointed that the rails on the roof are just cheap plastic so no chance of factory roof bars. They also look like they will be in the way of aftermarket roof racks.
    Has anyone mounted roof racks on the new 2018.
    PCSpaceShip likes this.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Pictures?
  3. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    Considering the Spark Activ has true roof rails this is disappointing...I imagine Thule or another brand offers adjustable bars that would work. Are the roof rails similar to the Calibers raised plastic pieces?
  4. Jimmyb426
    Victoria BC
    2017 Prius c
    It's interesting the plastic things are screwed down to the roof in 3 places each side, I wonder if Toyota will eventually offer real rails as an option. After going to my local roof rack specialty store the plastic rails are in the way of all the options that fit the 2017 model so no roof racks for me at this time what a pain in the &$@&@&.
  5. Jimmyb426
    Victoria BC
    2017 Prius c
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Thanks! I don't understand the logic on that... I would assume it would negatively impact mpg's. Why would Toyo make that standard?
  7. jimnjo
    jimnjo Member
    117
    2015 Prius c
    I had some trouble finding removable roof racks for our 2015 C (guessing same configuration in 2018...) but Rhino Rack made one to fit that is maybe the nicest rack I have ever owned. Wide enough for one canoe or kayak, I have added wood 'spreaders' to carry 2 alongside (of either craft) and once or twice, for short distances, tossed another boat atop all that. Fuel economy suffers with that load.
    LnG likes this.
  8. Maxcy18
    Maxcy18 New Member
    Vancouver
    2018 Prius c
    Anyone else have a solution to fix 2018 prius C roof rails problem. How can I install the roof rack. They drilled 7 hole on the roof for the roof rails but no use. I so disappointed.
  9. Tideland Prius
    16,681
    Purely cosmetic. It's only standard on the upper trims IIRC.
    ztanos likes this.
  10. Steeldriver11
    Steeldriver11 New Member
    Clemson, SC
    2018 Prius c
    I am currently encountering the same problem. Don't understand their function - TOYO says its to seal gaskets? No sense made. The issue is that you can't really find an aftermarket that will allow mounting to the outside, inside or top of that existing plastic rail without major interference to opening/closing doors.
    Anywho, I bought an aftermarket Rhino Rack 2500 and am in the process of making it work. I'm ultimately trying to get a cargo basket on top there. My theory so far - Unclip the caps, find a longer bolt, drill through Rhino footers, secure bolt through Rhino footers + plastic rail into roof. Then I won't need the securing clips. Is this safe or recommended? probably not. Will it hold? Should - the top of the car is rated to a certain weight upon rollover, so it isn't like it's pot metal up there. Should hold 50-60 pounds of cargo without an issue. Driving to a technician tomorrow to run my theory by him, will keep everyone posted.
  11. Steeldriver11
    Clemson, SC
    2018 Prius c
    Update: Cost was too significant to make this work (currently). All options save one involved drilling or tapping the roof and voiding the warranty. The only other option was to have a local machine shop create custom clamps to fit to the Rhino Rack in place of the ones they shipped with (also voids warranty since altering a manufactured product). Rhino Rack did refund me and apologize for their mistake (the rack was advertised as compatible with my Prius). I did speak to an engineer at Rhino Rack and they will be working on the issue since they pride themselves on offering as many options to different models as possible. Those with a moon roof - the Rhino Rack 2500 will work since you don't have the plastic rails. The rest of us - we're waiting for Rhino Rack (or competitor) to make a system that fits the existing Prius and their website has been updated to note the issue before you purchase.
    Those interested in the avenue's I researched:
    A. Drill into the roof, create footers and seal the holes - approx. $3200.
    B. Remove plastic rails, tap existing 6 threaded holes from screw to bolt, create footers and seal - approx. $2600.
    C. Use existing Rhino Rack ($350) and get a machine shop to create custom clamps to fit the car in place of the ones shipped with the rack - approx. $1800
    D. Talk to engineer @ Rhino Rack to create an option that works for Prius C with plastic rails - wait time approx. 6 months, no guarantee, estimate approx. <$400.
  12. Steeldriver11
    Clemson, SC
    2018 Prius c
    I don't get that. I get several answers from Toyota in a continual loop. The plastic rails are to cover the holes, or the holes were there to secure the plastic rails.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
  14. PCSpaceShip
    PCSpaceShip Member
    32
    29
    Kissimmee Florida
    2018 Prius c
    Has anyone tried rope through those pool noodles floatation devices? I have considered this for a surf board. improvising. And then duck tape to secure. Lol
  15. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    I just bought a 2018 Prius and noticed that one of my rail caps is missing and I’ve been looking for a Toyota part number any help for the part name and a part number to follow 8048B4EB-C10C-4C81-8C8B-5221E546A2FB.jpeg
  16. Mendel Leisk
    42,352
    Your avatar shows Prius Prime, you're in Prius c forum, and you say you bought a 2018 "Prius". Maybe clarify, it's a Prius c? And what level?
    I'm guessing you'll find it on this page:
    Exterior Trim - Roof for 2016 Toyota Prius C | Toyota Parts
  17. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    His avatar is a c;).
    This is what the front of the Prime looks like :):
    A slight difference(y).
  18. Mendel Leisk
    42,352
    Weird, text shows Prime (on a computer):
    Also, only certain Prius c levels have the roof rails?? Meh, search it up on McGeorge, Amayama. Local dealership will know too, hopefully accessible in these times.
    Raytheeagle likes this.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Who has a desktop pc anymore :p.
    On my iPhone all you see is the avatar pic and when you click on it, the vehicle doesn't show:cool:.
    Oh well, a search on toyotapartsdeal might also bring resolution(y).
  20. Leadfoot J. McCoalroller
    8,290
    7,804
    Pennsylvania
    2018 Prius c
    In the international Aqua family, the roof rails (and black fender flare appliques) are known as the Crossover Variant. It's not 100% clear to me how this variation got folded into North-American spec models but I believe it is all trim levels 2017-2019 inclusive.
