2018 Prius Four - cons
Discussion in 'Gen 4 Prius Main Forum' started by LilyT, Jan 26, 2018.
Tags:
  1. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    I chose to buy a 2018 Prius Four, because of some nice features such as, good mileage, 11.6" big screen, head up display, parking assistance, etc.
    After driving it around for two weeks, I've noticed a few areas that I wish could be better::
    Front seats dome lighting - too dim & narrow. It doesn't help me at all 1) to locate the garage door opener button (which is at the bottom of the rear view mirror), 2) to see the buttons on the door, or 3) to see the buttons around the 11.6" screen.
    The 11.6" big screen - too close to the driver. I have to take my eyes off the road in order to see the navigation map on the big screen, as a result, I try to avoid using the map that much which is okay at local roads but would be very inconvenient in unfamiliar places. I wish the map gets displayed at where the MID is located, closer to the windshield.
    Front nose - not enough clearance. When using a parking spot facing a concrete sidewalk in the front, it's easy for the nose to touch and rest on the sidewalk.
    Backup beep - annoying. I couldn't find a way to disable it.
    Storage on 4 doors - too small. I cannot fit a folded sunshade in there, or a file folder of A4 papers.
    Haven't explored all the features, but so far so good on others.
    RCO, Prodigyplace and bisco like this.
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Congrats on the purchase. Front nose clearance is bad for parking barriers. Easiest thing is to just back up in a space as you have a ton of room at the rear or just simply not pull all the way forward...which will take some time to judge it.
    Backup beep, either have dealer or disable thru Carista app.
    Storage is also poor from my previous car.
    Enjoy the great gas mileage.
    RCO likes this.
  3. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    Thanks, Rob!
    Good advice! I'll go check out the app you mentioned.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Talk to your dealer - should be part of pre-delivery service.
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    My dealer changed the beep...beep...beep...beep to one beep for us FREE...
    wastoooo and Prodigyplace like this.
  6. bisco
    52,848
    all good points lily, enjoy your new prius!(y)
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    Welcome!
    You might want to try turning on your parking lights. I do not have the fancy mirror, but on my 2017 all the other labels are lit whenever the parking lights or headlights are turned on.I would expect the buttons around the larger screen to be similarly lit.
    The storage in the doors is meant for a water or soda bottle and not much else, IIRC.
    Enjoy your new car.
    wastoooo likes this.
  8. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Google led replacement lights for 18 Prius interior, they are great.
    Get a carista obd2 gizmo, lots of customizations available.
    Pay attention to your surroundings, and listen to your proximity warnings, they tell you front and rear to stop before you touch something, the map will give you prompts for turns and will also show you on the screen behind the steering wheel, if you have the heads up screen it will also show up there.
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    @LilyT please update your user profile with your vehicle information so we can continue to provide appropriate advice.
  10. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    Wow, so many tips and congrats! Thanks to all! You guys are awesome!
    @Prodigyplace I tried to update my profile, but the 2018 model hasn't been entered into the dropdown menu.
    RCO and wastoooo like this.
  11. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I agree with about the storage compared to my Gen 2.
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    @Tideland Prius It is 2018. Please update the User Profile choices.
    SFO likes this.
  13. Tideland Prius
    16,680
    Done
  14. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    Sylvania offers replacement "Super Bright" white LED dome and map lights. The 2018 Prius isn't officially listed on http://www.sylvania-automotive.com yet but I'm sure they are the same as the '16 and '17...I would call them to confirm. Bulb replacement is fairly easy and the website has instructions.
    I have the SYLVANIA 168 ZEVO LED Mini Bulb's installed on my doors and they are brighter.
    RCO and Prodigyplace like this.
  15. padroo
    padroo Senior Member
    2,763
    2,253
    If you have all black interior even LED lights don't help as much as I hoped they would.
  16. Prodigyplace
    12,712
    11,848
    Central Virginia
    I thought the black interior looked too dark. I considered Moonstone but then this one with beige interior became available.
  17. LilyT
    LilyT Junior Member
    Seattle WA
    2018 Prius
    @padroo I do have a all black interior. I'm afraid that might be the case. I'm replying on my fingers (not my eyes) right now to locate the garage door opener button and the unlock all doors button. For the buttons around the 11.6" screen, I turn on the headlamp to illuminate them.
  18. alanclarkeau
    7,045
    7,593
    There must be a setting wrong - the "All Doors Button" is definitely illuminated at night.
    On LHD vehicles, you've got buttons (RHD have to go into settings):
    #18 alanclarkeau, Jan 27, 2018
    RCO likes this.
  19. Prodigyplace
    12,712
    11,848
    Central Virginia
    She has a 2018 with the large screen from the Prime. Our experiences may not apply.
  20. alanclarkeau
    7,045
    7,593
    OK - our 2018 still has the same screen - but it's still buttonless and knobless :mad:. But I'd be surprised if they shifted the buttons to the side of the steering wheel.
    RCO likes this.
