2018 Prius oil filter is a spin on now?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gas Mizer, Jul 27, 2018.
  1. Mendel Leisk
    42,373
    A lot of people here seem to do that, still: not for me. I'll raise the car using either the front or rear central jacking point. Never the side, seems to flimsy. Oil changes, I'll just raise the front as high as I can go.
    Tire rotations, I'll raise both: front end first, try to get it so tires are 1~2 inches clear of the floor, onto jack stands, then repeat at the rear. The object being to have all four tires just clear of the slab, easier on my back, lol.
    With minimal clearance under the tires, I can lift the wheels up and on with the help of a pry bar bar. I find if just muscle them on a day later my back is telling me about it. :(
  2. Gas Mizer
    Gas Mizer Member
    153
    50
    Redding, California
    2018 Prius
    DO NOT jack up the front on the 4th gen. They did away with that jack point. I jacked it up on what I thought where it was (because it's all covered in plastic now) and it turned out to be the radiator core support.
    krmcg likes this.
  3. Mendel Leisk
    42,373
    You know that's a red-flag-to-a-bull for me, right?
    From the 2016 Owner's Manual, page 590:
    Suspecting it's similar to third gen, it's a prominent low point on the engine bay lower cross beam.
    #23 Mendel Leisk, Dec 15, 2018
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    You’re always quick on the draw:).
  5. Gas Mizer
    Gas Mizer Member
    153
    50
    Redding, California
    2018 Prius
    Oh yeah, I was talking about up front further. The point your referring to is the sub-frame, which would definitely work.
  6. Mendel Leisk
    42,373
    It seems like if you roll under the centre/front, a typically-dimensioned 3 ton range floor jack with it's handle vertical, around the time the handle encounters the front fairing the jack cradle should be in the vicinity of the (designed) jacking point. The engineers think about the need, come up with something.
  7. UltraJetRefill
    156
    93
    Tucson, AZ
    That's what I ended up building for mine so that I could get under it to do the filter.
    pjksr02, marcnh, knockknock_2 and 3 others like this.
  8. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I know this goes against what this forum, and most of the internet, probably thinks but Chrysler has a better engineered design for how to use these cartridge type oil filters than Toyota does. On my Prius I have to be under the car and I use the special oil filter wrench to remove the filter cap because apparently my dealer likes to use air guns on those things. The first time I did it I had to use a breaker bar to get it to move, then let the oil drain from the filter. With Chrysler there is no special tool needed, just a large socket. The filter is at the top of the engine where it is easy to access and all of the oil drains out of it so you're unlikely to make a mess. So I'd be glad if my Prius had the spin on oil filter that the engine was engineered for rather than the what seems like a haphazard last minute update to use a cartridge style filter.
  9. marcnh
    marcnh Junior Member
    2018 Prius
    Yes I just find the biggest bolt and Jack it up there on one side for my oil change. I put big diameter maple wood supports for safety.
  10. Classic Car Guy
    Classic Car Guy Active Member
    506
    136
    Northwest, USA
    What engine oil and filter model number do you use on a 2018 prius hybrid base model with presently 14k miles in it?
