2018 Prius Prime - first time for tire replacement!
Discussion in 'Prime Main Forum (2017-2022)' started by withspirit, Aug 26, 2024.
  1. withspirit
    withspirit Junior Member
    16
    Birmingham, AL
    As a remote worker and now newly retired, I have put just 30k miles on my car in six years! Given that I still have 4/32nds tread, I cannot see why I would want to bother paying for tires rated to go mega miles as I wouldn’t be able to get my money’s worth out of that expenditure. I am considering either replacing the OEM tires - Toyo Nanoenergy A29 or even go with a less expensive Hankook while the Toyota tire sale is still on. Any opinions are welcomed. I don’t expect more mileage in the future as my car is not the road trip car (we own a hybrid Prius as well). Thanks
    52,854
    it's a personal choice based on many factors. my number one is noise level
  3. BiomedO1
    BiomedO1 Senior Member
    4,596
    2,410
    Left Coast
    I think you can probably go a few more years with the OEMs. I just replaced mine @ 40K, still about 1/32 from the tire warning strips.
    The reason I replaced them was there was a very good sale on tires with free install, lifetime balance w/road hazard; two of them had patches in them from nails. I went with a heavier thicker tire, hopefully less prone to flats. The tires has a slight shimmy, when first installed, it seems to have settled out after a few hundred miles. Haven't had it on wet pavement yet, but I'm assuming it'll do fine - Temp. A Traction A; rated M+S touring tires.
    If you're in snow country, you should probably pull the trigger sooner rather than later.
  4. withspirit
    16
    Birmingham, AL
    Thanks very much for the answers, especially the points from Biomed. I had just asked my husband if he thought we could wait a bit longer for replacement when I read your answer. I believe I will put a bit more mileage on them while I consider the choices. I want to get a good LRR tire at a decent price. I live in the South so no worry for snow either.
