2018 Prius Prime no longer getting 25 miles per charge
Discussion in 'Prime Fuel Economy & EV Range' started by Bejeffer, Dec 10, 2018.
  1. Bejeffer
    Bejeffer Junior Member
    Atlanta
    2018 Prius Prime
    I'm retired and don't drive PP every day. Noticed the last month I'm averaging less than 20 miles per charge....today it was about 18. It might be something I'm not doing or don't know to do.....I generally leave in the EV default mode. Suggestions? It's been cold here lately and I keep the temp up...could it be something that simple? Thanks
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The heater, rear defogger will reduce your EV mileage. I’m seeing a reduction as well.
    J
  3. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    You must mean actual miles, not the computer generated quess.
    In NH, summers the car guesses 32-34, now in 20-30 degree weather the computer is down to 22-24 miles per charge.
    So, assuming you mean actual miles driven, guessing they are at 75mph and yes cooler weather will require heat which eats mpg.
    I like to turn the ice on when going uphill or when at speed, saving the electric for around town and back roads (35mph)
    52,789
    welcome!
    it's winter, if you read the related threads, you will find that this is normal battery behavior.
    it will improve next spring.
    it has nothing to do with how much or often you drive, or anything else in your control.
    all the best!(y)
    Arctic_White and kenoarto like this.
  5. Bejeffer
    Atlanta
    2018 Prius Prime
    Thanks!
    thank you!
    Thank you!
    #5 Bejeffer, Dec 11, 2018
  6. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Should be back to normal by St. Patty's Day.
  7. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I've noticed a HUGE difference just between my range in November when the car was brand new, when I could get to work on all EV with 38% left and now I can't make it with more than 20% left with only 3,000 miles on the car. The overnight lows in November were in the 45°F range and today they're in the 50°F range. I'm not sure it's all temperature related.
    One way to verify that it's not anything you are doing differently is to check the daily log in the car to see if your average miles/kWh has changed. When I check mine, it's actually gone up which means my driving behavior hasn't caused a decrease in range.
    The only reason I'm not panicking over such a dramatic loss of range (23% decrease) is because if it continues at this rate they're going to have to replace the battery under warranty in short order (although my experience with Toyota suggests it might take court action to force them to honor any warranties they have).
    #7 PiPLosAngeles, Jan 20, 2019
    Arctic_White likes this.
  8. bisco
    52,789
    no warranty on range, specifically stated in the o/m. if history is a guide, it won't drop below 25 miles for a good long time
  9. PiPLosAngeles
    1,551
    724
    Range is irrelevant. It's all about battery capacity. That's why I don't bother with the miles display and only use the battery SOC. My "predicted range" is currently 38 miles, but that has no meaning. If I drive all downhill I'll get 75 - 80 miles, but if I drive all uphill I'll get 20.
    When your miles/kWh is stable and your range on the same drive is decreasing, that means the useful capacity of the battery is decreasing. Nissan is suffering from this issue with the Leafs.
    I know there's no warranty on range, but if the battery stops holding any kind of reasonable charge, it's a warranty issue. There are general fitness for purpose laws that override any manufacturer's disclaimers. They can't legally sell a battery operated car and say they don't guarantee the battery will work. Well, they can say it, but they can't practice it. If the range just decreases to a point where it's still considered "reasonable" and then levels off, then Toyota's off the hook. In that case, though, their reputation will suffer tremendously. Selling cars whose primary function degrades tremendously in a short period of time and giving customers the finger won't go well for Toyota for very long. They set a high standard with the PiP, which after 6 years and 140,000 miles still gets about 90% of the range it got on day 1. If they want repeat business, they can't continue selling cars that lose 50% of their performance in a year's time.
    EDIT - Also This Nissan LEAF Already Lost More Than Half Of Its Battery Capacity: Video
  10. bisco
    52,789
    no trouble codes, no warranty. range or capacity matter not. fitness for purpose lawsuit has never been tried, would be interesting, and costly.
    hopefully never comes to that
    #10 bisco, Jan 20, 2019
  11. PiPLosAngeles
    1,551
    724
    Unless Toyota royally miscalculated (like Nissan), or had a major supplier issue, I doubt the battery will degrade so rapidly in perpetuity. But in these days where manufacturers have been caught intentionally programming decreased performance into their products to encourage replacements, or tried substituting inferior parts in a system with an excellent reputation to "cash in" on word of mouth, you can never be sure what's going on. To some degree you just have to trust, but that's a delicate thing. It's difficult to earn and easy to lose.
  12. bisco
    52,789
    agreed. some people lose more capacity than others, as measured by kWh's accepted. no one knows why.
  13. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Maybe. But almost everyone is reporting a fairly sudden drop in EV range since about November, whether they've had their car for a year or three months, so it almost has to be weather related. It may not be just the battery, either. If one hasn't checked the inflation of the tires, colder weather might mean underinflated tires, which will hurt the efficiency of any vehicle.
  14. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    For me, my drop was due to using the heater, and I need the heater because of the interior fog that you get when it's not on.
    I've experimented with this, by switching the heat on only when the fog is too thick,, and my range improved.
    But I'm not a native of Massachusetts and I don't think that I will get use to it when the weather man says that the high today is 9F.
    I'm leaving the heater on and taking the reduced range
    jp
    Arctic_White and bisco like this.
  15. PiPLosAngeles
    1,551
    724
    When it's really cold, just turning it to the lowest setting (60°F) seems almost hot. I wish it could go lower for hypermilers. When it's 30 outside it sure is more comfortable when the interior's 50, and wouldn't hurt mileage near as much as 60 or 70. Manually activating and deactivating works, but distracts from driving and makes wear and tear on the rocker switch.
  16. J Mike
    J Mike New Member
    2018 Prius Prime
    Today (February 20, 2019) we visited our local Toyota dealer where we purchased our Prius Prime new last August. We have just over 6,000 miles on the odometer. Our predicted mileage range has been under 20 miles for over one month when fully charged and prior to moving from our heated garage - fresh start - no preheating, etc. Service tech at the dealership gave us a bunch of bull about our driving style, etc. that to our thinking should not change our predicted driving range in any way before we leave our heated garage. We were promised a 25 mile driving range on battery alone - why is that predicted driving range now under 20 miles?
    We then called Toyota USA (1-800-331-4331). They gave us the same bull about how much snow was on the ground and how we will be driving in the future. To our way of thinking, none of this should impact our predicted driving range before we leave our heated garage.
    Could we gain some insight from you, our fellow Prius Prime owners/drivers?
    Mike
  17. bisco
    52,789
    welcome!
    unfortunately, the mech and toyota are correct. no one promised 25 miles of ev range. it is an era test rating. 'your mileage may vary'.
    it is used for a comparison with other vehicles, just like mpg's.
    many things affect ev miles: speed, hills, acceleration, hvac usage, tires and pressure, weather and etc.
    under ideal conditions, many here get up to 40 miles of range. under not so ideal conditions, 20 is not unreasonable.
  18. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    I monitor, and suggest, looking at the display on the MID that shows the miles per kWh. The right column on the display shows the percentage of A/C load. The higher the A/C load, the more electricity being used to heat the car, and reduces the range.
    Yesterday, the display indicated 2% A/C load factor, and 4.5 miles per kWh. Mathematical, that would suggest I would have yielded about 27 miles.
  19. CraigM
    208
    208
    Portland, Oregon
  20. johnamerc
    johnamerc Junior Member
    47
    24
    Ithaca, New York
    2018 Prius Prime
    Been as low as 18 miles or so in snowy weather in Central NY my home base. On a road trip in the Southeast and just set a personal best Saturday driving North on FL 301 from Gainesville (Whole Foods . . . a nice place to charge) temps in the mid 80's no A/C 42 miles on that charge . . .Yeah!
    Arctic_White and benagi like this.
