2018 Prius Prime no longer getting 25 miles per charge
Discussion in 'Prime Fuel Economy & EV Range' started by Bejeffer, Dec 10, 2018.
  1. Ankana
    Ankana Junior Member
    Alta
    2018 Prius Prime
    Batteries discharge faster when they are cold. To make matters worse DC heaters are not very efficient.
    Arctic_White likes this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The Prime has a DC heater?
    Heat Pump and engine coolant yes but DC??
  3. Ankana
    Alta
    2018 Prius Prime
    Seat heater and any defrosters will be Direct Current Resistance heaters
    52,861
    i thought the ac was ac
  5. a_gray_prius
    2,927
    783
    IL
    Are you checking cold tire pressures? Your garage might be heated and register spec tire pressures, but once you go outside into the cold that air's going to contract. We've been over-inflating by a bit to get spec pressures at low temperatures (because I think the spec is set at not-20F).
    That said, our Model S is (very) noticeably slower when it's cold and I find myself not getting to my normal 275 Wh/mile rate until 30-40 minutes of driving, even with preheating. I've been assuming the Prime is pretty much the same.
    There's also a battery heater that is probably eating some of that power in both cars (although the one in the Prime is supposed to only come on with a charge cable attached, so I'm not sure).
    #25 a_gray_prius, Mar 19, 2019
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    First time since last Dec, my EV range GOM returns to above 25miles. Good timing that the gas price has gone up substantially in last few weeks.
  7. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    My GOM hasn't gone below 29 since I got mine in Jan. '17. Then again as @HPrimeAdvanced says, "I drive like a crippled snail" lol
    Arctic_White and Salamander_King like this.
  8. Salamander_King
    11,024
    8,980
    New England
    Yeah, if ICE stays off when I first start the car in morning, I can usually keep the GOM above 25. Today was the first such day, ICE did not start when I first turned on the car at 16F outside.
    Arctic_White and Prius from Dad like this.
  9. jfilipeferreira6
    jfilipeferreira6 Junior Member
    I get 45,3 miles (72km) EV-only everyday from work
  10. benagi
    benagi Active Member
    525
    280
    Utah
    Since the weather has warmed up to 60° here, my GOM is reading 31 to 32 miles these days. Not bad for a 2 1/2 year-old prime.
