2018 Prius Prime - Remote Engine Start
Discussion in 'Prime Main Forum (2017-2022)' started by SydneyNJ, May 23, 2019.
  1. SydneyNJ
    SydneyNJ Junior Member
    87
    24
    New Jersey
    2018 Prius Prime
    Hello,
    I'm new to this forum.
    I recently purchased a 2018 Prius Prime Advanced. I have been shopping around for a remote engine starter. The local (NJ) Toyota dealers do not provide this service. I called around and was quoted between $250 - $450 to get one installed. Per the manual, the car starts in EV mode if battery level is sufficient. Otherwise the gas engine will kick in. Here's my question: has anyone in this forum who has a remote engine starter installed and when you start the car, it starts in gas engine mode? I'm getting mixed answers and some professional installers said, however your car starts, that how the remote starter will start as well. Ideally I want the remote starter to start in EV mode all year around EXCEPT in winter months.
    Anyone can share some experience with what I'm looking to do?
    Thanks
  2. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    I'm guessing that you want the remote engine start to preheat the cabin in winter. If this is the case, you can simply use phone app to turn on the remote climate. I cannot think of any reason to need a remote engine start. Is this something one needs in cold climate?
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    My understanding is that for PRIME you can not start ICE while the charge cable is plugged in. I thought about installing a remote engine start to start the ICE remotely to warm-up the cabin during severe cold in winter (below 14F) when the heat pump is not effective, but since I do daily charge at night, and car has the charge cord attached in the morning when I need to start the car remotely. It defeat the purpose if I have to go outside and unplug the cord before remotely starting the engine. Thus I never installed it. There are a few in PC who had remote engine starter installed on their PRIME. They may chime in to answer your specific questions.
    heiwa likes this.
  4. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    If it's to cold or too hot the remote climate will not work
    Arctic_White likes this.
  5. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    During Winter months, I simply want to warm up the car for about 5-8 mins before I go out. I don't
    need to preheat the cabin. Though I do want to defrost the windshield but not 100% needed.
    So has anyone successfully have a remote engine starter installed on a 2018 Prius Prime?
  6. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    By the way, one of the professional installers said to me that he could program the module to send a signal
    which is equivalent of me pressing the "EV/HV" button to trigger the gas engine. As I said before, for the 2018
    Prime, when you "Push Start" -> car starts in EV by design (unless your battery is close to empty). Then if you
    push the "EV/HV" button -> it goes into hybrid mode. If temperature is low, gas engine will kick in. He said he
    could program the module to simulate these events.
    Anyone heard of this? True/False?
  7. bisco
    52,758
    if you leave the heat and fan on, the engine will come on and heat up the cabin, regardless of the mode.
    however, as sk mentions above, it will only work if you're not plugged in. the car will not start with the cable connected for safety reasons.
    there is a member here who is trying to figure a workaround, but so far, after looking at wiring and software and asking a million questions, he has not had any luck.
  8. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    bisco: i never have my charging cable plugged to the power inlet on the car overnight.
    So from what you're and SK are saying, sounds like it will work as long as I leave the heat/fan "ON"
    when I shut off the car. Then next morning, when I remote start the car (regardless of EV, HV or EV AUTO)
    I had it when I shut it off. Right??
  9. Washingtonian
    Washingtonian Senior Member
    726
    621
    To clarify things, the Prime has a gasoline engine and a DC motor. So the OP wants to remotely start the engine and not the motor. Is that correct? If so, why? If I were to do that, it seems like I would have an excellent chance of filling my garage and eventually my house with carbon monoxide.
  10. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    My car is parked on the driveway outside.
    I want the gas engine to start when I remote start it during winter months.
  11. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I think this is the case for too cold only. There is no hot limit that I am aware of (the A/C is designed to work up to very high temperatures - i.e. Phoenix in August). The 2018 owner manual (page 511) mentions only that "the system may not start when the outside termperature is very low", with no similar note for high temperatures.
  12. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Seems like there are difficulties or technical challenges for this 2018 Prime when it comes to starting the car vai a remote engine starter.
    Of all the cars I've owned, I always had remote installed (2008 Nissan 350z, 2009 Lexus RX350, 2008 Lexus CT200h (hybrid)
    and 2017 Lexus RX350). This is the first time I bought a PHEV - 2018 Prius Prime). I still have my CT200h. During winter months
    when the temp outside is cold, it starts the gas engine when I remote start it. The car automatically determines the outside
    temperature. After the car is "warmed up", the gas engine shuts off but the car is still "ON". So i'll go out; get in and go.
    That's it unless there's ice on windshield, then I have to scrape it.
    I am going to stop in at the dealer and talk to the techs and see what they say.
    Arctic_White and bisco like this.
  13. bisco
    52,758
    perhaps the o/p's car is parked outside
  14. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Sorry what's "o/p's"? :)
  15. bisco
    52,758
    original poster, you!(y)
  16. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Maybe one option is never charge the traction battery during the winter months. That'll definitely
    fire up the gas engine when I remote start it. In addition, charging may take longer when temp is low
    and the battery gets "discharged" when parked outside at night. Not sure what the right technical term
    is but you're probably know what I mean. So it's isn't efficient to use the traction battery in winter season.
  17. Salamander_King
    11,024
    8,977
    New England
    Are you saying you want "warm-up" the engine (ICE) but don't need to preheat the cabin? Why??? Modern car's engine needs no warm-up, especially PRIUS. If it's not for pre-heating the cabin, you would be just wasting gas.
    jerrymildred likes this.
  18. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Oh, really? I didn't know modern cars don't need the initial warm up even in frigid temps.
    I know, on my 2008 Lexus CT200h, if I start the car and drive away without letting the
    engine run for say at least 5 mins in cold temps, I can feel the car is working "harder" and
    i can feel it on my foot while stepping on the gas pedal. It's hard to explain.
  19. bisco
    52,758
    better to drive gently until it warms a little if you can. if you have a charge, you can drive ev while the engine warms up.
  20. Prodigyplace
    12,710
    11,847
    Central Virginia
    There is no need to start the engine to preheat the cabin. The Prime uses an electric heat pump to heat the cabin.
