2018 Prius Prime - Remote Engine Start
Discussion in 'Prime Main Forum (2017-2022)' started by SydneyNJ, May 23, 2019.
  1. SydneyNJ
    SydneyNJ Junior Member
    87
    24
    New Jersey
    2018 Prius Prime
    What I am trying to say is that there's such as thing as "engine warm up". It says that in the screenshot and the car
    does require an engine warm up though it maybe a short 2-3 minutes not the 5-8 mins that I normally do. I was almost led
    to believe the concept of "engine warm up" is a thing in the past. :) Not true according to that screenshot. Again this
    process maybe a quick 2-3 mins. So if your morning starts out cold, I don't know, say 15-20F, don't you want
    to warm up the car first then drive? I have been labeled as "old habits or misinformed" before. :)
    That's how this thread got started - about installing a remote starter to warm up the gas engine during cold
    winter months. If your answers are going to be same - no, it does not require engine warm up. That'll be fine too.
    But I still believe the concept of "engine warm up" still exists today (with modern cars). If "warm up" is a thing in
    the past, then the term "warm up" should not even be mentioned anywhere in the manual. :)
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    No, you don't need to have the car sit on idle to warm-up the engine. The engine warms up while you are driving. In case of PRIME, it will happen when ICE first starts that maybe 15 min after you started driving, or if your drive is short enough to be covered all by EV, then engine warm-up will not happen at all.
    jb in NE likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Yes. And the more quickly the engine warms up the more quickly it becomes efficient. This is why it's best to drive it while it warms up, so it will warm up more quickly. When the engine is warming, typically more fuel is injected to get the catalytic converter up to temperature.
    jerrymildred likes this.
  4. CharlesH
    2,798
    1,166
    Roseville, CA
    During this "warm up", the system operates so that essentially no power is transmitted from the ICE to move the car, whether you are moving or not. The ICE is operated at no load at a programmed RPM until a certain coolant temperature is achieved. If you are driving, the system will use the electric motor, dipping into the "HV" capacity if necessary, regardless of whether you have EV or HV set. It really tries hard to not put load on the ICE until it is warm. But you don't have to just sit still waiting for the ICE to warm up. The only reason for running the ICE before you get in the car is to warm the cabin for you. The system will take care of warming the ICE.
    #84 CharlesH, May 27, 2019
  5. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Well I won't experience winter until December.
    Will find out how the car behaves or how the drive is like then.
    Good discussions ...
  6. bisco
    52,849
    try googling 'should i let my engine warm up before driving'. very informative
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Now, we are finally getting somewhere. You made the assumption that "warm up" for a traditional vehicle is the same thing as "warm up" is for a hybrid. It is not.
    For a traditional vehicle, the term "warm up" means to get the engine up to a temperature with enough heat so that the output of the propulsion system is normal. A cold system will be sluggish. Engine oil, engine coolant, and steering fluid all work better when there's some radiant heat energy circulating through the propulsion system.
    That same definition most definitely doesn't apply to a hybrid like Prius. It uses 0W-20 synthetic oil in an engine designed for rapid heat distribution. The steering doesn't even have fluid, since it's electric. Most power provided during the initial operation of the engine comes from the electric traction-motor too. In other words, none of that heat is needed for driving.
    The "warm up" with respect to Prius is related to the emission system. For the catalytic-converter to cleanse emissions thoroughly, it must have heat to make the chemical conversion to take place... hence "gasoline engine may not stop" mention in the manual. Remember, cleaner emissions than traditional vehicles is a priority for Toyota's hybrid system. Engine warmth is used for that, but is clearly not necessary for propulsion.
    So, what you see in the manual is a misunderstanding. For Prius to be cleaner than traditional vehicles, it requires heat from the engine... hence the "warm up" mention.
    heiwa, Sarge and jerrymildred like this.
  8. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Yes, we are finally talking the meaning of "engine warm up". The way you described it clearly shows a major distinction
    in this technology. I will try to find out the type of engine oil that is currently in my car. My car is only 7 wks old
    and I'm now curious.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Synthetic.
  10. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    I know it's synthetic. But is it 0W-20 as mentioned by john1701a?
  11. Salamander_King
    11,024
    8,978
    New England
    Yes
    #91 Salamander_King, May 27, 2019
  12. bisco
    52,849
    look at your manual and oil fill cap.
  13. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    You guys are right about using 0W-20. I found it in my manual.
  14. bisco
    52,849
  15. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Our resident guru @john1701a always comes up with the perfect explanation. (y)
  16. Rawrxs
    Rawrxs Junior Member
    New York
    Idk if you got an answer to this yet, but in case you didn’t, you can install a remote start in the prime. I’ve had one for awhile now. In order to work, the car can’t be plugged in. We also toggled the HV switch that way it would work in low temps. I either didn’t charge during the winter, or just unplugged my charger before bed to accommodate for these issues. If you have any questions I’d be glad to point you in the right direction.
  17. bisco
    52,849
    what do you mean by 'toggled the hv switch'?
  18. Sid786
    Sid786 Active Member
    267
    148
    Cherry Hill, NJ
    I disagree with the above statement. My personal experience is that if there is no charge available then remote starter will not work. It is extremely convenient to defrost the windshield screen, if you heatup and defrost using remote starter. It saves atleast 15 to minutes of scraping in morning.
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    "if there is no charge available" means 0% indicated on the traction battery? Even at that level there is enough in the traction battery to start the ICE.
  20. john1701a
    12,840
    5,312
    58
    You cannot, since the comment was actually about being plugged in, not the charge. Notice the word "cord" was overlooked.
