2018 Prius Prime - Remote Engine Start
Discussion in 'Prime Main Forum (2017-2022)' started by SydneyNJ, May 23, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I never installed a remote engine starter on mine, since I always charge my car over night. For remote engine starter, the charge cord has to be removed. I think you are confused with the remote climate control feature of the Prime. For me that feature is worthless. It doesn't work when it's cold (below 14F), the heat pump is not effective.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    In Omaha Nebraska, the marginal last kWh is 9.36 cents in summer and either 7.46 or 5.27 cents in winter (depending on how much you use). Plus sales tax of 7.5%.
    Service Charge: $30.00/month
    Summer (June 1 – Sept. 30)
    • 9.36 cents/kWh for all kWh
    • For kWh consumption more than 100 kWh and less than 401 kWh, a credit of $2.07 per month will be applied
    Winter (Oct. 1 – May 31)
    • 8.63 cents/kWh for the first 100 kWh
    • 7.46 cents/kWh for the next 900 kWh
    • 5.27 cents/kWh for all additional kWh
      Minimum Monthly Bill: $32.07
  3. Rawrxs
    Rawrxs Junior Member
    New York
    Below/To the right of the shifter, there are a few buttons. Drive Mode, HV/EV, and EV Auto. When the remote start is installed, in order to not kill the EV battery, and also work in low temperatures, the installer should make the car starter activate that HV/EV button after the car starts. It’s just a programming thing, works perfectly.
    52,849
    thanks!
    no one else has been able to do that yet, so it would be helpful to the community if you could provide detailed instructions (y)
  5. Rawrxs
    New York
    I didn’t install it myself, so I can’t explain everything. It was done with a Viper Kit and installed at Best Buy. They know how to do it there, so if you want it done I’d start there.
  6. SydneyNJ
    SydneyNJ Junior Member
    87
    24
    New Jersey
    2018 Prius Prime
    Sorry for the late follow up to this thread which I started.
    I stopped by the shop where I had my Prime tinted but they also do remoter starters. The tech had spoken to their tech
    which I believed at Viper. They wanted this tech to do & observe somethings. That's why I had to go there. So this is what we did:
    1. We both sat inside my Prime - temp was around 80F that day
    2. "Push Start" the car and naturally it started in EV. This is by design.
    Battery level ~85%
    3. Turned on the AC and I set the inside temp to be around 68.
    Pushed the Fan to high. Sat there and car running for > 10 mins.
    No change in "State" - meaning the gas engine never kicked in.
    4. Pushed "EV/HV" button to go HV mode.
    Again, sat there for another 5 mins. No change in state.
    5. Now we turned OFF the AC and shut off the car.
    6. "Push Start" the car
    7. Set the cabin temp to MAX. - meaning we were simulating turning the HEAT ON and yes, it was 80F outside.
    As soon as the word "MAX' appeared on the screen, the gas engine kicked in.
    8. Repeated steps 5 thru 7; same results
    The tech said that's all he wanted to observe and will call their tech back.
    So I do believe it is possible to have a remote starter installed for what I want it to do in the Winter.
    I haven't call the tech to confirm.
  7. TonyaNorway
    TonyaNorway Junior Member
    Norway
    On my Prime here in Norway, pushing and holding the AC button on the keyfob will activate the cabin heating/cooling depending on it's last state.
    This works when the car is plugged in as well.
    Also pushing and holding down the keyfob doorlock button will cause the car to start beeping then raise any windows that are not fully up.
  8. bisco
    52,849
    any update?
  9. bisco
    52,849
    will it start the engine?
  10. TonyaNorway
    Norway
    No, it will not start the engine.
    As the heating/cooling system is electric, there's not really much point!
  11. bisco
    52,849
    that is the point of this particular thread :)
  12. thefranchise713
    thefranchise713 Junior Member
    75
    52
    Buffalo, NY
    2018 Prius Prime
    Precisely. Many of us live in climates where the temperature will sink below the effective floor (~11F) of the heat pump. To have heat, we need the ICE to start.
  13. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    Lol ....this YouTube video " extreme cold " at 6F make me laugh ..haha....come on... Up here we can get easily -25c / -30c during an entire month and this is cold but not extreme. I have seen worst ... Well , some Prime owners here gets a remote start engine installed + auxiliary module. The remote start put the car in ready mode then the auxiliary module activate the HV/EV button. Problem solved. And yes the car must be unplugged.
    #113 Flaming, Jun 27, 2019
  14. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    Sorry it has been a while since I replied to this thread. I recently had a Viper installed. Viper has an additional module
    which you need to purchase in order to simulate the pressing of the "HV/EV" button upon remote starting the car in order
    to kick start the gas engine. I opted NOT to get this additional module. It's doing what I wanted it to do with one caveat -
    you can't have sufficient traction battery. So, in the winter, I don't intend to charge my car as much. Since it's still Summer
    and hot & humid (95-100F), I have the benefit of remote starting my car with the AC "ON" as soon as I step out of the train
    when I come home from work. Starting the AC using the OEM fob is basically useless.
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't understand this part.
  16. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    You need to leave the traction (aka hybrid) battery low. If your battery is fully charged, it will NOT work.
  17. bisco
    52,849
    so, the car cannot be plugged in, and cannot have too much battery charge?
    meaning, you're basically driving it like a gen4 all winter?
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't understand this relationship. Is 99% OK? How does the battery SOC affect the remote start?
  19. bisco
    52,849
    maybe the only way the engine fires is to charge the battery
  20. SydneyNJ
    87
    24
    New Jersey
    2018 Prius Prime
    It doesn't affect the remote start. It affects how the car will start. You know that Prius PHEV by design starts in EV
    mode. I want it to start in gas mode.
