2018 Prius Prime Shop Service Manual and Error Code Scanner
Discussion in 'Prime Technical Discussion' started by BriDiyGuy, Mar 25, 2023.
  1. BriDiyGuy
    BriDiyGuy New Member
    2018 Prius Prime
    Hello,
    As a newbee to this site, I apologize if this is a duplicate of posts already here (my search to find was unsuccessful).
    Does anyone know where I can find a decent shop manual for my 2018 Toyota Prius Prime? I'm use to using something like a Haynes manual in the past on all my cars. The most recent one I can find from Haynes is a 2012 Prius. The issues I'm having on my 2018 Prius Prime are with the AC and looks like I will need to take the dash apart to address error codes the dealer found: B1441 - Airmax Damper Control and B1448 Face Servo Motor Passenger Side.
    In terms of error codes, is there a recommended scanner to use? I am using the Zurich ZR13 (updated latest firmware) but am not able to get any of the codes the dealer found. I prefer a scanner that also provides repair information/details.
    Thanks for any and all help with this!
    BriDiyGuy
  2. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    For the shop manual you won’t find the print version of the factory service manual since Toyota shifted over to an online pay by usage subscription service called TIS.
    For the scan tool I’m eventually going to give one of the OBD Link tools a try since my older Foxwell doesn’t support the Prime.
    52,878
    techinfo.toyota.com
    mini vci
  4. ChapmanF
    19,041
    techinfo.toyota.com used to be a good answer to the shop manual question, but we have a better one now:
    Toyota Service Information and Where To Find It | PriusChat
    It gives the techinfo URL, of course, but it also describes other options, compares costs, and gives an introduction to what you find in the different volumes and when you might want which one.
  5. bisco
    52,878
    thanks, i keep forgetting that
  6. Rober
    Rober New Member
    2018 Prius Prime
    Did you find the manual?
